transmission upgrade
alperx
PostPosted: Mon Sep 21, 2015 8:04 am    Post subject: transmission upgrade Reply with quote
hello
I saw that the shaft and the transmission on 924 is very thin and doesnt seem strong for a strong turbo setup.
which audi/VW stronger transmission fit in the 924 ?
Thanks
motormouth
PostPosted: Mon Sep 21, 2015 10:05 am    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?p=218956#218956
'nuff said
PostPosted: Mon Sep 21, 2015 4:04 pm    Post subject: Reply with quote
If i'm not mistaken Raceboy used the NA gearbox on his 2L turbo that made more power and torque than the standard 924 turbo.
Raceboy
PostPosted: Mon Sep 21, 2015 4:21 pm    Post subject: Reply with quote
Dutchpug uses 924 NA torque tube and trans on his ~400whp 924 2.0, the engine threw a rod after upping the boost to 2bars but no signs of damage on the torque tube after several years of abuse.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Mon Sep 21, 2015 11:19 pm    Post subject: Reply with quote
I thought I had read that with the 924NA torque tube it is very difficult to upgrade the clutch. How was that done?
Mike
'67 MG Midget Dp
Raceboy
PostPosted: Mon Sep 21, 2015 11:57 pm    Post subject: Reply with quote
I used Spec Stage 3+ clutch kit for 924 NA 215mm clutch, that was rated to ~400Nm iirc.
Pieter (DutchPug) had OEM pressure plate upgraded locally and used some other disc iirc. Check his thread, he wrote about it there.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Tue Sep 22, 2015 2:12 am    Post subject: Reply with quote
A 944 transaxle is also a direct swap you have a more common input shaft size.
Raceboy
PostPosted: Tue Sep 22, 2015 2:33 am    Post subject: Reply with quote
944 NA/924S trans is not stronger at all compared to 924 NA gearbox. Upgrade would be 944S/Turbo/S2 /968 6spd 01E gearbox.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Tue Sep 22, 2015 3:53 am    Post subject: Reply with quote
I am interested because I want to be able to use the 4.11 dif gear of my '80 rather than switch to the 3.889 of the 944 as in my looking at the Haynes manual the change over to the 944 torque tube to gain clutch capacity looked quite daunting if wanting to retain the higher gear ratio. But then I have never taken a transmission apart.
Mike
'67 MG Midget Dp
PostPosted: Tue Sep 29, 2015 7:33 am    Post subject: Reply with quote
Torque Tube isn't that bad to remove and install as long as you drop the exhaust and the rear suspension. Really, I was able to do this in my garage by myself with a standard jack and jackstands to hold the car up.
That said, if you just want to update to a 5-speed Audi box from a later small spline 924, then it should bolt up to your 77 torque tube with only a change to the later 5-speed shift arm. Clutch splines and torque tube should all work as before (though it might not hurt to refresh the bearings, bushings and other wear items while you're in there).
The 944 swap just opens up the ability to use some of the more common later transaxles and aftermarket clutch discs. Unless you're going to V8 power levels or doing a lot of rally or road racing, I don't know that it is ultimately worth it in most cases.
PostPosted: Tue Sep 29, 2015 10:33 am    Post subject: Reply with quote
I have a transaxle from an 81 924. Shipping cost moght be more than it's worth though.
alperx
PostPosted: Sun Nov 22, 2015 11:29 am    Post subject: Reply with quote
well
after all - I used a Hyundai diesel pressure plate with a 4-puck ceramic ACT clutch disc. we will see what happens.
