| Should I do it? |
| Yes |
46% |
[ 6 ] |
| No |
53% |
[ 7 ] |
| Total Votes : 13 |
Swakefield
Posted: Fri Dec 26, 2014 11:07 am Post subject: |
you will need a programmable engine management system / efi setup (fuel rail, injectors,bungs) and a custom turbo manifold... plus dump pipe to original exhaust pipe,
stock turbo manifold uses external wastegate, j pipe, down pipe and will not bolt to n/a head, also uses fire rings to seal and the recesses are also not machined the n/a head...
BTW you can still grenade your high compression motor off 9 psi from incorrect fueling or timing
Raceboy
Posted: Fri Dec 26, 2014 5:50 pm Post subject: |
You can turbocharge your engine without any custom manifold! Just make a crossover pipe and fit the turbo where CIS used to be if you will use EFI.
924 NA head has quite poor flow capabilities so the 9.3 compression is not the same as on say hi-flow 4v heads...
If you can fabricate some things yourself, definitely go for it because the car will be totally different and blast to drive. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
