ThomasJoseph315
PostPosted: Sun Oct 19, 2014 1:46 am    Post subject: ... Reply with quote
Last edited by ThomasJoseph315 on Sat Dec 12, 2015 5:45 am; edited 1 time in total
PostPosted: Sun Oct 19, 2014 2:02 am    Post subject: Re: What's the torque limit of stock CV Axles? Reply with quote
ThomasJoseph315 wrote:
I think I might have damaged one on the way to work this morning.
Good for you
http://www.924board.org/viewtopic.php?t=40537&sid=0bf0b580d2679b179494c453279e23e8
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Sun Oct 19, 2014 2:53 am    Post subject: Reply with quote
The answer is far more than a N/A 2.0 is capable of.
ThomasJoseph315
PostPosted: Sun Oct 19, 2014 3:57 am    Post subject: Reply with quote
PostPosted: Sun Oct 19, 2014 4:06 am    Post subject: Reply with quote
That's a fact
1980 931S
PostPosted: Sun Oct 19, 2014 4:14 am    Post subject: Reply with quote
Most 924/944/951 CV joints are nothing more than type 4 VW bus joints. PN 924 CV joints: 113.501.331DApplications:924 '76-82924S944 '83-89944S '87-'88944T '86-early 87 to chassis #95HN151524VW Type 4 Bus, VW Type 411
Like I said. More torque than a N/A is capable of.
PostPosted: Sun Oct 19, 2014 4:27 am    Post subject: Reply with quote
I killed a 944NA gearbox with my K27 turbocharged 924, but the CV joints are like new.
PostPosted: Sun Oct 19, 2014 4:32 am    Post subject: Reply with quote
That doesn't sound good for the 944 n/a box I bought for my 1.8 turbo swap.
edredas
PostPosted: Sun Oct 19, 2014 5:46 am    Post subject: Reply with quote
I have about 240 hp going to the wheels and my trans is still the original one that came in the car. However, there is an N/A in my shop as we speak with a blown diff from down shifting. Remember that when you park on a hill and put it in first gear that the full ~3000 lbs of weight can't turn the engine, yet when you down shift you can make the wheels turn the engine... this means you are putting far higher loads on the diff than it was ever designed for... just chew on that and you will see why there are so many broken ones.
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
PostPosted: Sun Oct 19, 2014 6:28 am    Post subject: Reply with quote
if you have a good condition gearbox you're probably going to be ok. that particular gearbox had some hard miles under its belt before i got it, i used it for a few years and then going uphill the diff just crunched when full boost hit.
