Turbo oil drain line adapter bolts torque??
kcoyle
PostPosted: Mon Jul 28, 2014 1:17 am    Post subject: Turbo oil drain line adapter bolts torque?? Reply with quote
Is this value....
These bolts???
I ask because I pooped myself this AM as I snapped one in half tightening it up to 61 ft/lbs. Crisis averted as there was enough bolt sticking out to grab onto with a vice grip.
CorsePerVita
PostPosted: Mon Jul 28, 2014 1:33 am    Post subject: Reply with quote
Sounds to me like one is likely NM and the other is FT lbs. 82nm is pretty close to 61ft lbs.
http://www.unitconversion.org/energy/newton-meters-to-foot-pounds-conversion.html
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
ptheskil
PostPosted: Mon Jul 28, 2014 7:35 am    Post subject: Reply with quote
Reading the table I think you want the line about 5 down from the one you circled at 29ft lbs so you were overdoing it some at 61.
1981 931 series2 Euro spec
PostPosted: Mon Jul 28, 2014 9:31 am    Post subject: Reply with quote
Those little bastards should not be tighter than you can go with one to two fingers on the end of a ratchet (read: 30-40 lb-ft).
kcoyle
PostPosted: Mon Jul 28, 2014 10:47 am    Post subject: Reply with quote
Cool, thanks!
