Horizonblue
Joined: 13 Oct 2011 Posts: 307 Location: Sorring city, Denmark, Europe
Posted: Wed Oct 02, 2013 6:28 am Post subject: Badge panel; welded versus bolted |
Has anyone ever replaced a "welded on" badge panel with a "bolted on" panel(panel between headlights)?
If so, what modifications needs to be done to complete this swap(drilling holes obviously, but what else)? _________________ Euro 924, 1976
/P.G. Andersen |
v8carreragts
Posted: Thu Oct 03, 2013 3:56 am Post subject: |
I replaced mine. I carefully cut out the spot welds with a spot weld cutter (looks like a very small hole saw) ground down the left over bumps. Then I lined up the new panel, drilled holes and used screws and nuts. The difficult welds are under the front right above the bumper. But overall it isn't too bad. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze |
Ponz
Posted: Thu Oct 03, 2013 7:51 am Post subject: |
I took a nose panel from my 944 85 1/2 and I did not encounter any welding taking it off. Might be a good start.
I still have it and it is in good shape.
vince _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
