xanderdeg
Joined: 08 Jul 2012 Posts: 286 Location: Vancouver, BC, Canada
Posted: Sat Mar 16, 2013 4:37 am Post subject: My horsepower is diddly |
My hp seems to vary from drive to drive. Some drives it's great and peppy, some drives it's a little lower than I'd like.
Is this possible or am I truly going crazy?
Maybe I need a vacation... |
Captain_Kirk
Posted: Sat Mar 16, 2013 6:14 am Post subject: |
Well, you do own a 924 so you're not totally straight in the head.
Is it feel like it's a fuel issue? Or what makes it feel like it's down on power? _________________ 1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body |
xanderdeg
Posted: Sat Mar 16, 2013 6:39 am Post subject: |
That is a very good point
Not sure, it runs smoothly all the time but just sometimes when I put down my foot the reaction is different than other times. Maybe its intake related or maybe distributor related, I'm not sure what to check..
I don't want to take anything apart just because my brain has a short circuit  |
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Sat Mar 16, 2013 6:55 am Post subject: |
What you may want to check is the distributor. Start there. Make sure it is tight and doesn't move. If you can move of if there is a bit of play in the distributor (you can move it to time the engine) that could be it.
Other than that maybe a vacuum line is loose.
Just my thoughts. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
xanderdeg
Posted: Sat Mar 16, 2013 6:57 am Post subject: |
| I doubt its a vacuum line, that would be more noticeable. I plan to check the distributor later today, see if its loose. |
xanderdeg
Posted: Sat Mar 16, 2013 10:05 am Post subject: |
Distributor is tight.
Checked everything else in the engine and all seems orderly.
It's probably just me being OCD/Paranoid  |
vatoisimo
Posted: Sat Mar 16, 2013 11:22 am Post subject: |
| it still could be a vac line. I had a vac line on my boat that was a little loose. It would run fine, untill it got a little warm, and then the motor ran like crap. |
xanderdeg
Posted: Sat Mar 16, 2013 12:31 pm Post subject: |
Well I think you all are right. Just today it started showing signs of a mild vacuum leak. (idling a bit low and shakily as well as not cooling as efficiently)
I'm flying down to the states tomorrow for a week so the car will sit in the garage for a week but when I get back i'll do a full diagnosis.
Thanks for your comments, it definitely helped me out! |
