Posted: Mon Dec 12, 2011 7:58 am Post subject: Street driveable coilovers |
I'm interested in what you guys would consider a good price/performance street coilover solution for our beloved 924.
ofcourse i'm refering to the wide body...aluminium arms suspension.
KW offers some solutions around 2000 euros....~$2700
i'm driving my mk3 golf since about a year with the KW type 3 coilovers and they are a bit unconfortable...they make the car rattle, especially when using 205/40/16 tires.
now i dont use the 924 as a daily...and i use it only on good roads...but i'd hate the 924 if it would rattle.
anybody using coilovers that they would recommend? _________________ Supercharger and EFI kits
https://www.the924.com |
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Mon Dec 12, 2011 9:10 am Post subject: |
I think the ground control ones are cheaper. The Hypercoil ones from Paragon are even cheaper but they are only for the front. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Mon Dec 12, 2011 2:06 pm Post subject: |
Brand doesn't matter as much as matching the spring rate to the shock rates. Don't use solid upper mounts and the ride will be less harsh/noisy.
As for what spring rate/shock settings to use? I don't really know. Everyone has different thresholds for noise/bumpy rides. There is information around the web that will provide you some equations to use to determine some ballpark ranges to shoot for. However, this assumes you know the specifications of the shocks settings, etc. _________________ Stefan
Posted: Mon Dec 12, 2011 4:29 pm Post subject: |
It depends on how you plan to use your car, track racing, street driving? Is the car stock today in the suspension ? _________________ 1980 924 Turbo
Posted: Mon Dec 12, 2011 6:29 pm Post subject: |
fiat22turbo, i'm also looking from the price perspective...2000 euros for a coilover is alot here....a very good salary is maybe 800 euros netto.
i'm going to use the car 95% on the road, but i'm looking for a more one piece feeling. I love the mk3 with the KWs...well except for the rattling.
Also, i'd like to adjust the ground cleareance within a fine margin...without going trough the t-bar reindexing nightmare again.
At the moment i have the factory setup...actually i have a weird setup.
REAR: ROW 924 torsion bars thats 22mm IIRC, mated with 951S arms and stock ROW sway bar....14mm IIRC....all this lowered (reindexed)
this is too soft...this feels like a boat compared to my mk3 on kw.
FRONT: 931 suspension but with harder springs (3 blue spots) with a 944 sway bar...23mm IIRC
this is also a soft... _________________ Supercharger and EFI kits
Posted: Tue Dec 13, 2011 2:37 am Post subject: |
Yup thats a very soft setup, problem is thoug that the cheapest kits dont have the perfect setup, often it gets uncomfortably bouncy. My friend had a 944s2 race car with Leda suspension calculatet and simulated by a experienced race engineer, that car fast insanely fast and at the same time pretty good on the street, just an example.
But just for having a nicer feeling of the car most kits are just too much money. Have you checked GAZ kits? _________________ 1980 924 Turbo
Posted: Tue Dec 13, 2011 3:28 am Post subject: |
i found some koni shocks for the rears that sound like a good upgrade...but without stronger t-bars...i'm not sure it will work very well.
for the fronts i'm still looking for solutions, i have yet to find a price catalog for GAZ products :| _________________ Supercharger and EFI kits
Posted: Tue Dec 13, 2011 3:35 am Post subject: |
I would look into buying the larger T-bars and Bilstein shocks/struts. Koni's are nice if you need adjustment, but it seems like the Bilstein's are pretty close out of the box. _________________ Stefan
Posted: Wed Dec 14, 2011 12:37 am Post subject: |
The Paragon front kit is $265 (choose your own spring rate with name brand springs), I would trust that before I would trust the "Mookeh" brand.
Also, cip-1 has VW t-bars for quite cheap. _________________ Toofah King Bad
Posted: Wed Dec 14, 2011 5:15 am Post subject: |
ofcourse i couldnt agree more, i'm just going trough all the options avaliable. _________________ Supercharger and EFI kits
Posted: Wed Dec 14, 2011 5:40 am Post subject: |
I would either purchase a full set of ground control coilovers OR the paragon front kit. _________________ [This Space For Rent] |
Posted: Wed Dec 14, 2011 4:19 pm Post subject: |
If I were in europe I would buy this kit instead:
http://www.rallydesign.co.uk/product_info.php?products_id=3450
They also have a big assortment of springs, much cheaper than paragon kit.
Track proven on some 924s, including mine
They also sell GAZ dampers, I have that combination on my car (60N/mm ~350 lb/inch), together with 28mm bars from cip-1 mentioned above. But coil over at the rear would have been nice, although it wasnt so hard to change bars and get correct ride height. There is quite a lot of adjusment availbable on the eccenter screw. _________________ 1980 924 Turbo
Posted: Wed Dec 14, 2011 6:22 pm Post subject: |
...the eccentric scew is a nasty thing i dont like the way it changes the geometry
As my car goes fairly slow for 90% of the time on the street...and it rarely puts much load on the suspension....until now my favorites are:
front: the kit from rallydesing + springs and bilstein shocks
rear: rebushed beetle coilovers (still waiting on an answer on the spring rates on those things)
Not interested to go as cheap as possible but it appears that this solution is also easy to install and set..at least compared to installing different t-bars.
As a side note, i have my MK3 TDI with very expensive KW suspension..thats around 1800euro...and a friend of mine bought TATechnincs coilovers for 300euro...the difference is not that great...the KWs are somewhat more confortable...and it seems a tad more stable in the corners...but the differences are minimal and i'm running 205/40/16 tires and he is on 195/50/15. _________________ Supercharger and EFI kits
Elektrobank
Joined: 19 Mar 2007 Posts: 149 Location: Pozzuoli,Napoli, Italy
Posted: Thu Dec 15, 2011 12:18 am Post subject: |
| Cédric wrote: | If I were in europe I would buy this kit instead:
They also sell GAZ dampers, I have that combination on my car (60N/mm ~350 lb/inch), together with 28mm bars from cip-1 mentioned above. But coil over at the rear would have been nice, although it wasnt so hard to change bars and get correct ride height. There is quite a lot of adjusment availbable on the eccenter screw. |
i have som GAZ shoks on my 2wd sapphire cosworth and they work very very well! i purchased them from rallydesign many years ago, everything was perfect at the time except the communication and the waiting.... more than one month to deliver the parts!! _________________ 924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
lot of fun but always on foot.... |
