Tie Rod Gebafflement
PostPosted: Fri Aug 12, 2011 1:41 am    Post subject: Reply with quote
Get them while they are hot:
AutohausAZ.
VERIFED TO FIT.
FWIW, this is the "early style" tie rod with female threaded outer tie rod ends. . .the ONLY way to use the Elephant bump correction kit.
tyfighter123
PostPosted: Fri Aug 12, 2011 8:44 am    Post subject: Reply with quote
Rasta so you ordered 2 of the right sides? Or did you order a left and a right?
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
PostPosted: Sat Aug 13, 2011 3:41 am    Post subject: Reply with quote
Two of the above.
tyfighter123
PostPosted: Sat Aug 13, 2011 4:30 am    Post subject: Reply with quote
Thanks just ordered 2.
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
stevekat
PostPosted: Sat Aug 13, 2011 4:35 am    Post subject: Reply with quote
What is the difference between left and right?
PostPosted: Sat Aug 13, 2011 5:34 am    Post subject: Reply with quote
Probably thread direction for the adjustment.
!tom
PostPosted: Sat Aug 13, 2011 2:09 pm    Post subject: Reply with quote
Is this part (right side) supposed to be a replacement for the tie rod in the 477 419 803 B assembly? I'm not 100% sure what you men by female threaded outer ends; do you mean female tie rod ends, or female threaded ends of the tie rod (different parts)?
I need a new tie rod as I've got a bent one.
The picture looks like it's right, but your description has scared me off so far.
78 924 NA
5-lug
!tom
PostPosted: Sat Aug 27, 2011 12:33 am    Post subject: Reply with quote
For these tie rods, only the outer tie rod end is different between left and right. They've got a bend to accomodate the wheel at full lock.
As we'd be turfing the outer ends anyway, it doesn't matter to us, as I can confirm the tie rods themselves are identical left to right. If you do order a pair, left and right, at least you'd have a set of ends to give to a 'dubber.
The other option mentioned earlier in the thread (20 mm shorter) has a non-adjustable left tie rod, and all the adjustment is in the right side. But those are too short anyway, so it doesn't matter.
78 924 NA
5-lug
PostPosted: Sat Aug 27, 2011 3:47 am    Post subject: Reply with quote
The rod is male threaded, for a female threaded TRE. The part now being sold as the superceded part is the opposite.
!tom
PostPosted: Sat Aug 27, 2011 4:53 am    Post subject: Reply with quote
One potential incompatibility.
There is no room for part 477 419 827 callout 3A, stop ring, with these new tie rods.
I'm not too sure what they're needed for.
78 924 NA
5-lug
PostPosted: Sat Aug 27, 2011 5:49 am    Post subject: Reply with quote
Probably to keep the pinion gear from hitting the end of the toothed section on the rack to protect it. I believe I tossed them on both my cars, but something to keep in mind.
*EDIT*
From 944 FSM:
Probably cheap to have them turned down a bit.
mikeycrum14
PostPosted: Wed Feb 22, 2017 2:35 am    Post subject: Reply with quote
so...
ive been reading this page and researching a bunch.
my 81 924 has the drivers side inner tie rod that needs to be changed.
where to find/buy?
Crossover parts?
1981 924 - Alpine White, First car! LSD. - SOLD
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap
stevekat
PostPosted: Wed Feb 22, 2017 4:05 am    Post subject: Reply with quote
I believe I had ordered mine through ebsracing.com, but it was 2009. If they do not list it, give them a call. My old part number for them may have been POR019838. OCAP. I think this was the inner.
mikeycrum14
PostPosted: Wed Feb 22, 2017 4:49 am    Post subject: Reply with quote
they don't have it any more on the website... I might give them a call. any other suggestions?
mikeycrum14
PostPosted: Wed Feb 22, 2017 5:07 am    Post subject: Reply with quote
will the assembly from autohaus fit a 81 N/A? and is there such a thing as a inner and outer tie rod? or just inner and outer tie rod ends?
Page 3 of 4
