jamis1970
Joined: 08 Oct 2010 Posts: 56 Location: big bear lake 92315
Posted: Sun Jul 17, 2011 2:01 pm Post subject: Quick question about steering column |
Hello all. About two weeks ago I notice my steering wheel was developing some movement. The wheel seems to have about 3-5 mm of movement up and down, side to side ect. i thought the steering wheel nut was working loose so I removed the wheel and re tourqued it down. The nut was fine. I cant seem to figure out where this play is originating from, The steering u joints seem tight no play- is there something im missing? Is there a sleeve or bearing in the column i need to get to? Thanks! _________________ 1979 924 N/A Not Fast, but a BLAST to drive. |
MRPETE
Joined: 07 Nov 2010 Posts: 67 Location: CALGARY AB CANADA
Posted: Sun Jul 17, 2011 2:45 pm Post subject: |
Yes _________________ '77 924
"81 924
Lots o' Corvairs |
Posted: Sun Jul 17, 2011 8:41 pm Post subject: |
Yes, there is a bearing in the firewall that the column pass through. Royal PITA to change with the car all together.
I would double check both u-joints on the secondary shaft that attaches the column to the rack, however. In my experience, that is almost always where the slop develops. The best thing to do would be to remove it so you can check it thoroughly... _________________ erstwhile owner of just about every 924 variant ever made |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Sun Jul 17, 2011 9:22 pm Post subject: |
Hmm strange answer Dan, my experience is different.
Yes the needle roller bearing in the firewall can develop slop but it won't manifest in up/down movement in the wheel itself. It's not too hard to change out either once you have removed the steering shaft fore and aft of the firewall.
There is a sleeve bearing ("support ring" position 12A in illustration 403-5 in PET) just in front of ignition switch that when worn or missing (like in my car) will give the wheel a good 5mm of play up and down. So much so that it will rattle up and down when going over bumps.
My previous owner jammed a plastic fitting in there to stop the rattles and I removed it without thinking, creating the problem. _________________ 1979 931 with a 350 chev
1973 911E with EFI
| p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
Harm
Posted: Sun Jul 17, 2011 9:49 pm Post subject: Re: Quick question about steering column |
^What he says.
Some usefull info came by last week…
how do you replace ignition switch bearing
Regards, Harm.
Edit01 …too quick
Ozzie
Posted: Sun Jul 17, 2011 9:50 pm Post subject: |
There is an article on replacing an ignition switch at clarks garage. This bearing in the steering column causes most of the problems you describe.
do a search here.
http://www.clarks-garage.com/
The bearing can be bought as a separate part. Bit of work to replace but fixed all my problems. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
jamis1970
Posted: Mon Jul 18, 2011 1:33 pm Post subject: steering |
Thanks for the info everyone. Is the plastic sleeve easy to replace? anyone done it before and any caveats _________________ 1979 924 N/A Not Fast, but a BLAST to drive. |
Ozzie
Posted: Mon Jul 18, 2011 10:28 pm Post subject: |
The plastic sleeve the bearing sits on, comes with the bearing.
This is not available as a 924 part.
However if you download a 914 PET catalogue it is listed.
Cost was about $25 a few years ago. _________________ Porsche 924 1984 (UK import) NA
