dreamgts
Posted: Fri May 20, 2011 9:45 pm Post subject: Head Porting Diagram/schemetic |
Hi guys, does anyone have a diagram or schemetic of where to and where not to port/polish a 924 N/A head.
Thanks
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Sat May 21, 2011 1:25 am Post subject: |
Match the ports to the manifolds, and reduce the amount of material around the valve guide. _________________ Toofah King Bad
Martijnus
Posted: Sat May 21, 2011 1:33 am Post subject: |
Don't polish the intakes. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Sat May 21, 2011 11:34 am Post subject: |
Some say its ok to get rid of the flat top on each exhaust side port..
and maych it to a header or whatever your runnin .... others say thats a no - nooo beacuse the flat spot creates turbulance and speeds up
the exhaust flow ... me I went ahead & made it round. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
dreamgts
Posted: Sat May 21, 2011 9:22 pm Post subject: |
So what is best therefore is to work on a guide gasket based on the intake manifold,, should we just port the outer section and form the port as a cone type or do we have to remove material from the inner port? It seems the water jackets are pretty easy to go thru when porting around /near these. Is it a good idea to ploish the inlet manifold too once we are at it?
Martinjus, any particular reason why we shouldnt polish the intakes? the vehicle is going to be webbered?
Joe924racer, what do you mean exactly by the flat top of the exhaust side port?
Thanks
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Sun May 22, 2011 4:57 am Post subject: |
| dreamgts wrote: |
Martinjus, any particular reason why we shouldnt polish the intakes? the vehicle is going to be webbered? |
Fuel atomization, if you Webber this is even more important than it is with FI since carbs don't atomize as well. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Sun May 22, 2011 12:20 pm Post subject: |
Ill put up a pic here shortly. _________________ 1979 porsche 924 Na
Posted: Mon May 23, 2011 1:05 pm Post subject: |
Use the intake/exhaust gasket as a guide and scribe a marking around the inside circumfrence
Next using a cutting burr trim to around half an inch to inside the runner to get most of the edge cleaned
Then blend this into the runner about another inch in so tha the transition is smooth
on the intake pay particular attention to the roof of the runner as rhis has a casting ridge that will need to be smoothed, use your fingers to feel out the lumps and bumbs and then after youve finished with the majority of burr work use an 80grit flap wheel to give the whole runner a clean
On the bowl side theres not much you can really do, trim around the valve stem guide and casting to get this to a nice point and again smooth the ridge along the inside radius.
Exahust ports are a little better so again blend the gasket side and give the runners a tickle
The do your manifolds, and wear goggles when you do the cast iron manifold as they get in your eyes and it a trip to the doctors to get the filings out
All an all without a flow bench you cant really do much _________________ 1981 ROW 924 Turbo -
Posted: Mon May 23, 2011 6:27 pm Post subject: |
Head porting is a trade, if you dont know what you are doing with airflow, then you will likely make it worse. _________________ 3 928s, |
simsport
Posted: Tue May 24, 2011 6:05 am Post subject: Protection |
Burr tools can go bang, and alloy in the eye is no joke, wear the right gear!
cheers
Simon _________________ Blown is always best! |
gegge
Posted: Tue May 24, 2011 9:10 pm Post subject: |
| Lizard wrote: | | Head porting is a trade, if you dont know what you are doing with airflow, then you will likely make it worse. |
+1 _________________ Carl Fredrik Torkildsen
Posted: Wed May 25, 2011 7:48 am Post subject: |
+1
I followed a really good article in street machine that was produced by a head porting shop.
As I said I would consider what we can do as "head porting" is basically port matching of the gaskets and a clean up of the runners to remove restrictions.
If you stick your fingers inside the runners it doesn't take a genius to work work out where there are inconsistencies in the casting process.
You might also check out the pricipal of having a reversion dam when doing the exhaust ports.
Somewhere in here there's a post on 931 head design where the concencus of most board memebers was actually a redesign of the intake runner completely.
The easier method is to change pistons and use a 931 head, ala D prod, but you will end up with an interference design staying with the N/A application and have to use a custom piston to get the right compression height.
Time to get out the engine calculator if going this route.
gegge
Posted: Wed May 25, 2011 8:05 am Post subject: |
David Vizard has written a very good "porting school" that I do recommend reading. Just google. It does cover the basics as well as advanced stuff. Everything dynotested, not only with flowbench.
There is another very good forum - Speedtalk. Highly advanced indeed but educational and free. _________________ Carl Fredrik Torkildsen
dreamgts
Posted: Wed May 25, 2011 6:04 pm Post subject: |
The porting is going to be done by a pro, he immediately noticed the restrictions which when compared to what is posted here seemed to be correct.
He was a bit concerned since he did not know the amount of metal he could grind off since he has never done a 924 head before and also had no measurements etc.
I beleive this info was not available for a number of years. I told him I might be able to get him some sort of diagram, which I did, from a thread posted by endwrench about the subject showing a cott out diagram of the head.
It seems he has a better picture now of the head structure and design. I think his main concern were the water jackets. If its not too expensive We might attempt to air flow test the head, if we do I will post the results.
Thanks all for contributing.
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
