Ian89C4
Joined: 01 Apr 2011 Posts: 561 Location: North Carolina
Posted: Wed Apr 06, 2011 6:43 am Post subject: Lowering an '81 924 |
Hello all,
Newbie question here. I have an '81 924 I am prepping on a tight budget for Auto X / eventual SCCA ITA/ITB racer. I have many questions, but the one puzzling me right now is how to lower the rear of the car? I don't have much experience with torsion bars.
My current plan is to put Weltmeister sport springs on the front of the car along with Koni sport shocks - hopefully lowering the front around 1.5 inches and firming it up a bit.
For the rear - I am puzzled. I plan on putting Koni sports on the back, but how do I actually lower it without breaking the bank on a full coil-over kit? Or is that the only way?
Thanks in advance!!!!
Cheers,
Ian _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Ian89C4
Posted: Wed Apr 06, 2011 7:33 am Post subject: |
Awesome!! I will give that article a read and see which Torsion bars I will go with. I will probably have more questions later.
Cheers,
North Carolina
Current:
Posted: Wed Apr 06, 2011 1:04 pm Post subject: |
A 924 can be lowered practically to the ground without touching the torsion bars, but it requires some mods to the springplates and I feel a little too taboo to describe here. You will also have to reset your other rear alignment values, especially camber.
 _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Wed Apr 06, 2011 1:31 pm Post subject: |
Doesn't fix the lack of spring rate necessary to not run out of travel when driving quickly, like on a track or on an AutoX course.
New Torsion bars and/or adding coil springs are the only ways to increase the spring rate. _________________ Stefan
Posted: Thu Apr 07, 2011 5:01 am Post subject: |
| fiat22turbo wrote: | Doesn't fix the lack of spring rate necessary to not run out of travel when driving quickly, like on a track or on an AutoX course.
Obviously not. One of the reasons why I never posted anything about it on the board. On this particular car I had adjustable koni shocks set stiff and never had any bottoming or rubbing issues. Infact the car was so rigid it was uncomfortable to ride in on anything but a flat road and i ended up backing the damper setting to about halfway. I am sure stiffening shocks without adding stiffer springs put an undue load on the shocks, but again I never had any problems. It was fun to look at but I eventually raised it back to stock height and sold it. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
