Are there mods that can increase my fuel economy?
finaltable
PostPosted: Sat Feb 12, 2011 7:34 am    Post subject: Are there mods that can increase my fuel economy? Reply with quote
On Feb 14th I begin the 924S project previously referenced here.
I am going to be using my soon-to-be 924S for a daily commute, roughly 25-30 miles each way on winding state highway roads. I'd like to get the best mileage that still leaves me with adequate performance. I also don't want a car that sounds like one of these fart cannon equipped import jobs either.
Any thoughts?
Drive Fast, but Stay Straight
StienbargerR
PostPosted: Sat Feb 12, 2011 8:20 am    Post subject: Reply with quote
I'd say the best thing you could do for gas mileage is just replace the simple stuff like filters, the cap and rotor, plugs, and fresh oil. Other than that, I dont think there is much else you can do aside from making sure everything is in good working order. Just keep the revs low and you should probably get pretty good mileage.
1978 924 NA
-250lb lowering springs, Euro Pistons
PostPosted: Sat Feb 12, 2011 8:44 am    Post subject: Reply with quote
check the AF meter unit..that should be in perfect condition to deliver optimum mileage.
gegge
PostPosted: Sat Feb 12, 2011 8:51 am    Post subject: Reply with quote
Increase tyre pressure to 45psi, max 50mph, allways use the highest gear possible and buy large rear tyres in order to keep the revs down. And by largae I mean LARGE (not wide!). Check that the bearings are fine, the rotors are straight and the pads are not dragging.
Carl Fredrik Torkildsen
PostPosted: Sat Feb 12, 2011 8:06 pm    Post subject: Reply with quote
Put a block of wood behind the throttle pedal. That will stop you using too much gas!!
PostPosted: Sun Feb 13, 2011 12:24 am    Post subject: Reply with quote
I was going to say take some weight off your right shoe.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
PostPosted: Sun Feb 13, 2011 3:12 am    Post subject: Reply with quote
Also alignment - for instance, incorrect toe settings (both front and rear) can cause left and right wheels to be constantly traveling toward or away from each other, so they're scrubbing the pavement diagonally. That loses you mileage, tire tread, and traction.
Stoney13
PostPosted: Mon Feb 14, 2011 3:05 pm    Post subject: Reply with quote
1.wheel alignment
2.wheels balanced
3.comfort tires
4.increased tire pressure
5.tune-up
6.unclogged exhaust
Cruising at a constant speed of 35mph.
I am car biased. Not brand wise or motor size. I don't like crap plain and simple.
1978 924 N/A
2011 Ford Ranger
!tom
PostPosted: Mon Feb 14, 2011 4:47 pm    Post subject: Reply with quote
light weight engine oil will decrease fuel usage too.
78 924 NA
5-lug
PostPosted: Wed Feb 16, 2011 4:52 am    Post subject: Reply with quote
When cruising if your foot isn't numb from holding the throttle as steady as possible you are not doing it right. Don't accelerate and de-accelerate constantly. This means ignore others around you and anticipate the traffic around you so you are not getting all jerky on the throttle.
Follow BMW's ancient recommendation of accelerating hard to cruise speed and then cruise as described above.
I am very good at pulling major MPG's out cars while not appearing to be a hypermiler (i.e. holding up traffic).
There are more radical things you can do but these are the easiest to start.
I don't have a 924 record yet since none are running at the moment in the fleet but here are my current records.
BMW330Ci 35mpg (US!) over 700 miles mixed but mostly highway, loaded
GMC Acadia 26mpg (US!) over 700 miles mixed but mostly highway
Camry Hybrid 52+mpg (US) over 500 miles more mixed than above ( 60% highway and 30% back roads, FULLY loaded)
All used the technique as described but modified for how I felt the individual vehicle liked it.
924 records to follow especially from the '80NA since that is a major goal
924aussie
PostPosted: Wed Feb 16, 2011 8:04 pm    Post subject: Reply with quote
Put an electric motor in it or two
http://www.evalbum.com/imgm.php?n=3001a.jpg&w=300&h=200
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
Tam Lin
PostPosted: Thu Mar 03, 2011 10:53 pm    Post subject: Re: Are there mods that can increase my fuel economy? Reply with quote
Any thoughts?
I do 85 Miles a day, at speed. I've got a 3 l engine, which helps some. What I really recommend is the 944Turbo box. Fifth is much more of an overdrive type ratio, and saves I'd guess 3-5Mpg. Also, don't drive at night. having the lights flipped up looses 2-4 Mpg
YMMV
