camfella
Joined: 20 Jul 2010 Posts: 42 Location: Ottawa - Canada
Posted: Thu Nov 04, 2010 8:54 am Post subject: Sunroof compatibility? |
I was wondering if an early model(pre 85.5) sunroof will work in an 87?
It looks like the front hinge mounts are different and the rear needs the plastic cups for the sunroof lifting arms.
I also noticed a difference in the seal used on earlier models. The earlier models seem to use a much smaller seal than the later models.
with some small modifications, can an early style roof work with a later model?
Thanks,
cam _________________ 1987 924s |
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Thu Nov 04, 2010 9:01 am Post subject: |
Do you have an automatic or manual sunroof? _________________ 1980 924 NA
1982 931 |
camfella
Posted: Thu Nov 04, 2010 9:09 am Post subject: |
Sorry, should have mentioned it is a automatic powered sunroof. _________________ 1987 924s |
BionicBalls
Posted: Fri Nov 05, 2010 2:03 am Post subject: |
Then nope. They are the same size, but are a little different in design on the rear of the panel to accommodate the powered lifting arms. I believe the front clips and mounts are the same though. _________________ 1980 924 NA
1982 931 |
camfella
Posted: Fri Nov 05, 2010 7:24 am Post subject: |
The rear plastic hardware is installed for the arms on the sunroof.
I'm not sure about the front latching mechanisms. Im not sure if the pre 85.5 has a different set up with the latches where they flip down and rotate..... _________________ 1987 924s |
BionicBalls
Posted: Fri Nov 05, 2010 1:00 pm Post subject: |
The front latches don't rotate, any year should work. _________________ 1980 924 NA
1982 931 |
Posted: Sat Nov 06, 2010 12:31 am Post subject: |
Later 944 sunroofs have a different curve to early 924/944 _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
camfella
Posted: Sat Nov 06, 2010 9:07 am Post subject: |
Good news indeed. Thanks guys, appreciate it! _________________ 1987 924s |
Insane
Posted: Thu Dec 23, 2010 6:40 pm Post subject: |
| BionicBalls wrote: | | Do you have an automatic or manual sunroof? |
is there an original manual sunroof for 924?
have you got a pic of how it looks like????
I've got a non-working automatic one so I'm interested on how to swap to manual control. |
