Ds1
Posted: Fri Oct 22, 2010 12:46 pm Post subject: So I'm wondering... How to 'slam' a 924? |
I want to slam my 924, but I wanna do it cheap. It doesn't have to handle, it doesn't have to have a good ride, it just has to be cool.
This isn't something I would normally ever, ever do... But I'm bored.
How do you suggest to do it?! I promise to post pics as a reward for your help  _________________ www.thehighstudio.com
"Its Porsche time" |
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Sat Oct 23, 2010 2:02 am Post subject: |
Reduce the ride height by 5 inches.  _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Ds1
Posted: Sat Oct 23, 2010 2:04 am Post subject: |
Lol. Oh and one other thing I should've mentioned is "simple, cheap, and SAFE(ish)." _________________ www.thehighstudio.com
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Oct 23, 2010 2:41 am Post subject: |
500 pounds of sand is cheapest
Weltmeister springs in front and lower rear torsion bar is next cheapest.
Coil overs in front and/or rear would be most spendy. _________________ '80 924 Turbo - SOLD!
Porscheless  |
Ds1
Posted: Sat Oct 23, 2010 2:43 am Post subject: |
how much does a rear torsion bar go for? _________________ www.thehighstudio.com
Posted: Sat Oct 23, 2010 3:20 am Post subject: |
Actually, just re-index the existing rear torsion bars to the new ride height you want and cut some coils off the front springs. No cost, just wasted work. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Ds1
Posted: Sat Oct 23, 2010 3:24 am Post subject: |
| Fifty50Plus wrote: | | Actually, just re-index the existing rear torsion bars to the new ride height you want and cut some coils off the front springs. No cost, just wasted work. |
I like this idea a lot. Explain some more! _________________ www.thehighstudio.com
Posted: Sat Oct 23, 2010 3:40 am Post subject: |
http://www.clarks-garage.com/shop-manual/susp-06.htm
Keep in mind that the spring rate won't change so you'll basically be running on the bump stops. This is a dangerous way to drive.
A better idea for your "solution" would be to removing the torsion bars altogether and install shorter shocks with adjustable coil springs.
The front is essentially the same as a 1st gen rabbit, check out the VWVortex for information on their idiocy called "hella flush" that should give you all the information you need and we won't have to read about all the problems you encounter. _________________ Stefan
Ds1
Posted: Sat Oct 23, 2010 3:47 am Post subject: |
| fiat22turbo wrote: | http://www.clarks-garage.com/shop-manual/susp-06.htm
While staying in LA with my brother, we blew out one the air shocks on his E39 5 series wagon... being the only car for the both of us, I had to ride around LA for about a week on bump stops... needless to say, my kidneys where angry with me.
Anyway, thanks for the info. I am strongly considering cutting them, and maybe put in the 'proper' parts later... Either way I will be sure to let you know how horrible the ride is  _________________ www.thehighstudio.com
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sat Oct 23, 2010 12:34 pm Post subject: |
How to slam a 924:
First you talk about how it's not really a Porsche with it's VW van engine and all.
Then you can say it's butt ugly with all it's narrowness and how the US models have those ridiculous round reflectors and stupid bumpers.
Then you can mention how the '44 is a way better car and looks so much better, and even the 914 is far superior.
Oh, don't forget to say how they don't hold their value no matter how much money you dump into it.
I'm sure I'm missing something...Oh...what was this about? Never mind all that .
I get it now, I'd like to go about an inch or two...  _________________ I got nothin'
Uhhh...you got any pics? |
germ924
Joined: 04 Aug 2006 Posts: 233 Location: chino valley, Arizona
Posted: Sat Oct 23, 2010 12:45 pm Post subject: |
[quote="joejax"]How to slam a 924:
I'm sure I'm missing something...Oh...what was this about? Never mind all that :oops: .
I get it now, I'd like to go about an inch or two... 8) :wink:[/quote]
you crack me up joe |
Posted: Sun Oct 24, 2010 3:31 am Post subject: |
I would buy some used weltmeister springs and cut 3-4 of the dead coils off.
Then take out the rear torsion bars and re index them. I'd suggest getting some thicker ones, since if youre going to go through the trouble of reindexing you might as well spend a couple hundred dollars to get stiffer bars. 30mm in torsion bars and welt 250s in front.
Total spent: $300
Ride quality: Not Total Crap
Hella Flush: Yes
For extra canibeat cool points, purchase optional $99 mookah camber plates and find some 195mm wide tyres for your 9 inch rims.. _________________ [This Space For Rent] |
Ds1
Posted: Sun Oct 24, 2010 7:59 am Post subject: |
Does anyone have or know of any used weltmeister's for sale? _________________ www.thehighstudio.com
Posted: Sun Oct 24, 2010 9:26 am Post subject: |
In not too long, I should have a set. Otherwise ebay or paragon has them. _________________ [This Space For Rent] |
Ds1
Posted: Sun Oct 24, 2010 9:34 am Post subject: |
let me know a price when "not too long" happens! _________________ www.thehighstudio.com
