LEACKAGE UNDER DASH ON DRIVERS SIDE
TheChrisSummers
PostPosted: Sat Oct 16, 2010 11:12 am    Post subject: LEACKAGE UNDER DASH ON DRIVERS SIDE Reply with quote
I'm Having leakage problems up under the dash and drips right where your feet are. Anyone have any similar problems or any know how's on fixing it?
1987 Porsche 924
Will never buy another car besides a Porsche
D Hook
PostPosted: Sat Oct 16, 2010 1:00 pm    Post subject: Reply with quote
Check your antenna wiring where it goes through the body. Missing or loose grommet will allow water in. Have to pull the charcoal canister to see it.
'80 924 n/a SOLD
ole billy
PostPosted: Sat Oct 16, 2010 1:13 pm    Post subject: Leakage under dash Reply with quote
Between the heater and the windshield wiper motor in the area just behind the engine firewall there is a hole about the size of a quarter facing to the front of the car. This goes to the inside. There is also one on the passangers side. These are not the ones that drain into the engine compartment. All should be cleaned so water off the windshield can drain into the engine compartment. Hope this helps.
John_AZ
PostPosted: Sat Oct 16, 2010 11:20 pm    Post subject: Reply with quote
Cracked firewall on drivers side.
Check for cracks where the clutch pedal/ brake pedal connect to firewall.
Common.
http://kevingosselin.blogspot.com/2009/02/firewall-gooooo-and-pack-those-bearings.html
GL
John
'88 924S 67K
'87 924S 122K -DD
Past: 1970 914 1.7, 1977.5 924, 1979 924, +++== Gone, Past tutors
924guy
PostPosted: Sat Oct 16, 2010 11:40 pm    Post subject: Reply with quote
if above fails, follow the hood hinge up below the windshield, and check for rust pin holes in the cowling area. some removal of what used to be rubberized undercoating type stuff may be required, but its probably hard as a rock and will chip right off....
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
