Posted: Mon Sep 20, 2010 1:07 am Post subject: Wiper Relay |
OK, I have read a kazillion threads about wiper switch, relay, and grounding problems. Forgive my denseness, but things electrical take a long time to soak into my brain.
I just installed a new wiper switch, and the wipers are always on intermittant (in both intermittant, and OFF position). Prior to replacing the switch, it occassionally gave me random wipes.
I know I need to get under the dash with the multimeter, but I still have a quick question. . .is it POSSIBLE for a bad wiper relay to give this symptom? If so, how likely? It looks like the actual relay is operated by solid state circuitry of some kind. _________________ Toofah King Bad
Ozzie
Posted: Mon Sep 20, 2010 7:50 am Post subject: |
doubt it- sounds like a wiring fault _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Mon Sep 20, 2010 8:09 am Post subject: |
So, looking at the diagram, I need to test the pin coming from the switch at "S1" - which goes br/bl at the wiring harness plug. If this pin gives ground in the off position, the switch is bad, right? _________________ Toofah King Bad
Ozzie
Posted: Mon Sep 20, 2010 11:34 am Post subject: |
I think you will find S1 is ground or live depending on switch position.
its very possible the cams in the motor are gunked up too. _________________ Porsche 924 1984 (UK import) NA
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Mon Sep 27, 2010 11:34 am Post subject: |
mine did that when i had a bad ground.
now i have a vw relay and i dont have intermittent. just two "off" settings, slow, and fast. it was free, so i cant complain. _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
