Posted: Sat Jan 02, 2010 11:45 am Post subject: Plumbing in a boost controller |
I'll be adding a boost controller shortly to the 941. However, I do not want to butcher the stock wastegate actuator line, given their rarity. Does anyone know where I can find metric to hose barb fittings? The wastegate actuator line has M12x1.5 threads, but I can't find any hose barb fittings with metric threads, only SAE. Ideas? _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Sat Jan 02, 2010 1:42 pm Post subject: |
Maybe an adapter bushing from M12 1.5 to something common sae like shown on this website http://www.egauges.com/vdo_indA.asp?PN=R7962 _________________ Custom means it didn't come from a box.
Posted: Sat Jan 02, 2010 2:39 pm Post subject: |
Good luck, i searched all over for the female fitting to adapt a barb fitting the charge tube side of the actuator line.. _________________ [This Space For Rent] |
Min
Posted: Sat Jan 02, 2010 7:13 pm Post subject: |
Thanks Min! I ordered one each of the M12x1.5-to-1/8NPT and M14x1.5-to-1/8NPT bushings from egauges.com. There is actually a male-to-male M14-to-M12 reducer between the actuator line and the charge tube, so both sizes are needed. I'll then pick up some cheap 1/8" NPT to 1/4" hose barb fittings from the local hardware. _________________ erstwhile owner of just about every 924 variant ever made |
stevekat
Posted: Sun Jan 03, 2010 10:23 am Post subject: |
I believe an alternative is to pull the pressure signal from the over-boost switch port on the charge tube to the top port of the waste gate. Just work out a 'T' arrangement at that port. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Posted: Sun Jan 03, 2010 3:39 pm Post subject: |
Yep that's easy way to do it and parts are at every hardware store.... _________________ White 87 924S "Ghost"
jazz guy
Posted: Sun Jan 03, 2010 5:11 pm Post subject: |
[quote="stevekat]I believe an alternative is to pull the pressure signal from the over-boost switch port on the charge tube to the top port of the waste gate. Just work a 'T' arrangement there.[/quote]
My buddy did it this way. Worked great. As Paul says, Easy.
I cut into wastegate line, which is what you're trying to avoid. It has worked well for me.
Cheers, Brian |
stevekat
Posted: Sun Jan 03, 2010 6:26 pm Post subject: |
I've done it both ways but kind of like leaving the waste gate signal line intact now a days, particularly since the alternative is easy. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
jamespipers
Posted: Fri Sep 03, 2010 4:16 am Post subject: |
You should consider the size of the pipe when you are going to add a boost controller. And you might need an adapter bushing for the controller. _________________ My online plumbing |
Posted: Fri Sep 03, 2010 4:40 am Post subject: |
found a way to have a NA fuel hoose fit...but looks stupid with that extra hoose....so giving the fact that i have spare WG line...i decided to cut one and put in the boost controller.
Plus..there is a company here that can re-make that hoose as new for cheap. _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
