Feeler FS: AWIC
v2rocket_aka944
PostPosted: Tue Aug 03, 2010 4:39 am    Post subject: Feeler FS: AWIC Reply with quote
Guys,
Some time ago I bought an AWIC off a Jaguar XJR-6 (stock 320HP) to try to use on my 944 supercharger project. I am getting closer to finishing the project but am concerned I may not be able to make use of the IC as it is a pretty large item and space is quite limited as the SC is large itself.
This unit has a factory provision on the underside for an air-temperature sensor which I would include.
In the event it just doesn't fit for me, would anyone here be interested in buying it? I cut off the 6 jaguar runners and it could use some cleanup work before putting new runners on it. From memory this would probably fit in roughly the space of the intake plenum. I can give you better dimensions later.
Here's what it looked like originally:
And with runners cut off:
Next to 944 runners for size comparison:
I'd like to get what I have into this back if I sell, $100.
v2rocket_aka944
PostPosted: Tue Aug 10, 2010 3:55 pm    Post subject: Reply with quote
Went back to the parts yard today and I'm fairly certain that this AWIC would fit on a 931 between the valve cover and the throttle. I'll try to get an actual measurement next time though
