ole billy
Joined: 03 Feb 2006 Posts: 49 Location: Lafayette, CA
Posted: Mon Jun 28, 2010 3:01 am Post subject: Electric windows |
| Have a 87 924S with problem at the passanger window switch. Both windows will operate up and down from the dirvers side. The passangers side will only go down with that switch. Will not go up, but the drivers switch will make it go up. Have switched the switches from side to side and still not working. Have tried three other switchs and no. Don't really understand the Haynes diagrahm. Since the right window will go down there is power to that side and since the window will go up and down from the left switch the motor is working. I have pulled the door panel and cleaned the contacts. Any thoughts or experience in this area will be appreciated. |
Coolbri1191
Joined: 07 Feb 2010 Posts: 78 Location: Simi Valley, CA
Posted: Mon Jun 28, 2010 10:35 am Post subject: |
bump!
same problem except my passenger switch doesn't go up or down, but driver's side works. Tried two switches that worked on drivers side but still no go. Help would be appreciated  _________________ Guards Red 1987 Porsche 924S (Automatic)
2001 Ford Explorer Sport (DD) |
sbarc
Joined: 01 Feb 2010 Posts: 545 Location: West Coast of Canada
Posted: Mon Jun 28, 2010 12:08 pm Post subject: |
Mine don't work at all....either switches either window.....nothing.......I hope to take the switches out this week and check for current and start by cleaning the switches. _________________ 1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT |
Posted: Mon Jun 28, 2010 12:09 pm Post subject: |
My S does the same, I think it is a break in the wiring. The loom going into the door looks awful. _________________ Toofah King Bad
ole billy
Posted: Tue Jun 29, 2010 9:34 am Post subject: electric windows |
Found a window wiring diagrahm at Clark's Garage. Upon close inspection, I had the sw adjusted incorrectly. The Pass sw on the drivers side and on the pass side have to be adjusted so that the brass strip makes contact on the thin curved end in the nuteral and pressed positions. This lets 12+v go through the drivers side (pass sw) and over to the pass side sw.
The curved thin end has to be at the pin #5 end and on the other side at the pin#4 end. Following the diagrahm you will see how the current passes through the sw on drivers side and goes over to the passangers side sw. So, without removing the door panels, was able to adjust the sw's and now all windows work as you would expect. Hope someone with picture tallent will post this in the HOW TO |
