Which AFR Gauge?
Goto page Previous  1, 2
Which Gauge?
AEM
42%
 42%  [ 3 ]
Innovate
57%
 57%  [ 4 ]
Total Votes : 7
Min
PostPosted: Fri Apr 23, 2010 7:03 am    Post subject: Reply with quote
but when in tweaking and tuning mode, it's still going to change too fast to make a difference while driving.
That's not really true from my experience.
Min
PostPosted: Fri Apr 23, 2010 8:57 am    Post subject: Reply with quote
I have it about as lean as I dare at idle, and it still goes full rich at WOT
Do your pressures test within specs? If so, perhaps you could try unplugging the WOT line to the TPS and see if your fatty fatterson improves.
emoore924
PostPosted: Sat Apr 24, 2010 2:38 am    Post subject: Reply with quote
fatty fatterson
Hey, I don't have a fatty fatterson.
Is that an upgrade or did it come from the factory.
Rocco R16V
PostPosted: Sat Apr 24, 2010 2:45 am    Post subject: Reply with quote
emoore924 wrote:
fatty fatterson
I think that is something guys get to sit in the pass seat.
PostPosted: Fri Apr 30, 2010 7:01 am    Post subject: Reply with quote
Went for the AEM. . .under $200 with free 2nd day delivery at AEMOnly.com.
Carrera
PostPosted: Fri Apr 30, 2010 5:02 pm    Post subject: Reply with quote
AEM was my choice as well.
The analog gauge looks good. I guess that one is rather new as a couple of months ago when I got mine, I only found the AEM UEGO with the digital+led gauge.
Anyway, after a bit of "web-studies", I came to the conclusion that AEM was mechanically a bit more accurate and realiable than Innovate...
931 S2, 1981
Rocco R16V
PostPosted: Sat May 01, 2010 12:05 pm    Post subject: Reply with quote
does the AEM use the common Bosch sensor?
Carrera
PostPosted: Sat May 01, 2010 6:27 pm    Post subject: Reply with quote
Yes, the AEM comes with the common Bosch sensor.
931 S2, 1981
Arvidw
PostPosted: Mon May 10, 2010 6:57 am    Post subject: Reply with quote
The white version of the Innovative gauge:
It's quit bright, but i'm pleased with this gauge. Nice response, clear and until now reliable. (running with CIS and stock ignition)
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
Page 2 of 2
