dash16
Posted: Sun Apr 25, 2010 4:30 am Post subject: tail light Q |
The bulb on the very left only turns on when I press the brakes. This doesn't seem right as when I turn the lights on, only the bottom right bulb turns on, which is dim and seems dangerous. Should the bulb to the left be on as well and only get brighter when i press on the brakes? _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Sun Apr 25, 2010 5:38 am Post subject: |
your car is working 100% as intended.
its a pretty common mod to get a second bulb holder and put it in the middle "dead cell"
i did it and it is a cheap and easy safety measure _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
AppleBit
dash16
Posted: Wed Apr 28, 2010 12:18 pm Post subject: |
wow, so its only the bulb in the bottom outside corners that stay lit?
sketchy lighting on Porsche's part
thirdgenbird
Posted: Wed Apr 28, 2010 12:57 pm Post subject: |
maybe, but it i think it looks great. like i said however, for safety reasons, i added a bulb in the dead cell. if you want pictures, let me know. _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
thirdgenbird
Posted: Wed Apr 28, 2010 1:44 pm Post subject: |
sorry for the phone pictures, but get two of these:
and you can make your lights look like this:
