mystery gear box part
engineer.white
PostPosted: Mon Mar 15, 2010 6:37 am    Post subject: mystery gear box part Reply with quote
found on magnetic drain plug of my 1982 931
1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930
462avi
PostPosted: Sat Mar 20, 2010 5:19 am    Post subject: Reply with quote
Looks like a detent from one of the synchronizer hubs. Do you have a picture of the other side?
Geoff
2005 C230K
2002 grand cherokee with 4.7L
ic932
PostPosted: Sat Mar 20, 2010 7:39 am    Post subject: Reply with quote
Ouch, I had the exact peice come out of an Audi box (86' 944) never bothered to investigate as I had already found it during an exploratory oil change before a road test. 2nd gear almost impossible to select.
emoore924
PostPosted: Sat Mar 20, 2010 1:57 pm    Post subject: Reply with quote
Ditto on the detent. I think they might be different for each syncro, so you might be able to tell which one fell out. But unfortunately... I think its a remove, disassemble and repair regardless of which one fell out...
Might be cheaper to buy a replacement tranny...
engineer.white
PostPosted: Sun Mar 21, 2010 4:41 am    Post subject: parts Reply with quote
The transmission is out, if I can track down a good parts car, I may put in another transmission. Funny thing is this box shifted really well and made no bad noises. I will snap a pix of the other side tonight.
1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930
