TBrown
Joined: 28 May 2009 Posts: 72 Location: Noblesville, Indiana
Posted: Sun Mar 14, 2010 8:37 am Post subject: I cant do it captain |
After breaking the threads off the o2 sensor and taking my exhaust off again, I just got all put back together and running. Idle and timing are spot on. Im trying to use a dwell meter to adjust my air fuel mixture. Im turning the 3mm allen one eighths turn at a time and weighting 10 seconds for the engine to adjust. Ive turned it cw and ccw till the engine stumbles and set it right in the middle but the meter stays at 55 degrees. I dont want my mixture to be to lean and get detonation. Does anyone have any experience using the dwell meter method. Ive gone through all the posts using the search feature and I cant find anyone who has had this problem.
I know how much yall like pictures so heres the broke threads in the exhaust and o2 sensor.
 _________________ Tangerine Dream- 1980 924 Turbo
Silver Surprise- 1979 924 Turbo
1977 International Scout ii
1982 Yamaha Sr185
1978 Kawasaki KZ650
1974 Honda CB360
1973 Honda CB750 |
Jaf
Posted: Tue Mar 16, 2010 7:43 am Post subject: |
Erm, I've never heard of a method of using a dwell meter to set the fuel mixture. I thought the meter was only ever used to show how long the points are open? How did you connect the meter? _________________ 1978 924na |
Benino
Joined: 30 Jan 2003 Posts: 508 Location: Vista, CA (San Diego County)
Posted: Tue Mar 16, 2010 8:47 am Post subject: |
I'm not completely sure of this because I've never had the wiring for the idle switch connected on my car... but it could be that the computer sets the frequency valve at some set frequency when the idle switch is clicked, which would explain why you always see 55 no matter how u have your 3mm adjuster set. I know the full throttle switch does this to ensure that the mixture is sufficiently rich at full throttle. you might want to unplug the idle switch wiring at the throttle body before trying to set the air fuel mixture with the dwell meter.
Again, just a guess on my part.
I have successfully used a dwell meter to set my mixture in the past and I don't have the idle switch wiring connected. _________________ 1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA |
TBrown
Posted: Tue Mar 16, 2010 1:00 pm Post subject: |
| TBrown wrote: | | I think I got it pretty close with the stumble to stumble and then in the middle method. I actually richined a little more just to be on the safe side. |
That has always worked well for me. Final tweak can be made by checking the plugs after a day of good driving. I have a Gunson GasTester, but have never been able to get it to work well with the 931. It works great on my NA, but not on the 931 for some reason. _________________ erstwhile owner of just about every 924 variant ever made |
Jaf
Posted: Wed Mar 17, 2010 4:44 am Post subject: |
Good job my car's a 1978 and doesn't have O2 sensors and other complicated things. My little brain says "errr". I still forget which way to turn the dissy to advance the spark...never mind I'll go away now. Good luck! _________________ 1978 924na |
TBrown
Posted: Wed Mar 17, 2010 11:45 am Post subject: |
Haha yeah I'm happy with it I've got about 700 into it total without insurance and plates that's later this week
Now all I have to do is fix he oil leak from my distributor housing, it's leaking right onto my exhaust manifold  _________________ Tangerine Dream- 1980 924 Turbo
1982 Yamaha Sr185
1978 Kawasaki KZ650
1974 Honda CB360
1973 Honda CB750 |
Benino
Posted: Thu Mar 18, 2010 6:12 am Post subject: |
Just a couple more comments on the air fuel mixture adjustment.
Under normal warmed up operation, as long as you aren't way off with the air fuel ratio adjustment screw, on cars with the o2 sensor, your air fuel ratio will be correct. The frequency valve will adjust the mixture based on input from the o2 sensor.
However... When the engine is cold or when the full throttle switch is engaged, I believe the o2 sensor is ignored and the frequency valve goes into a set duty cycle to ensure a constant air fuel mixture. Under either of those conditions, the air fuel mixture very much depends on how the 3mm adjustment screw is set. _________________ 1980 Porsche 924 N/A USA
alexvex
Joined: 31 Jul 2006 Posts: 420 Location: Seattle, WA (from Indiana)
Posted: Wed Mar 24, 2010 2:51 am Post subject: |
Good to see you're still working on it and not giving up! _________________ --Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951 |
Slam
Posted: Wed Mar 24, 2010 6:16 am Post subject: |
Benino has it. Engine temp makes a big difference for the simple reason the O2 sensor won't talk to the control unit when it's cold. There's also a temp sensor that you need to check to make sure it's talking to the control unit when it should. Are you shooting for 45 on the dwell meter?
Interesting that this came up now, because I just learned about this method from a friend of mine and tweaked the mixture on Chrenan's old car. Boy did THAT wake it up! _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
