Joined: 29 Jul 2001 Posts: 9076 Location: Royal Oak, MI, USA
Posted: Fri Sep 13, 2002 11:38 am Post subject: |
The lines often get clogged with algae; clean thoroughly. The pump motor could be bad or more likely not getting power. Check at the pump motor connection for power first, using a voltmeter or test light, then go from there.
