will these work on my NA?
paulsmaroon924
PostPosted: Sat Nov 14, 2009 6:03 am    Post subject: will these work on my NA? Reply with quote
spotted these on our fav auction site.
am fitting the audi 5000 TB as soon as it arives, need more power and beter fuelling from what i have. one of the injectors is leaking and i saw these...........
will they fit?
what else would i need to manage them?
http://cgi.ebay.co.uk/924-G40-POLO-RS-TURBO-FIESTA-RALLY-RECON-INJECTORS_W0QQitemZ110449446983QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item19b74cd047
BionicBalls
PostPosted: Sat Nov 14, 2009 7:12 am    Post subject: Reply with quote
NO.
1980 924 NA
1982 931
BionicBalls
PostPosted: Sat Nov 14, 2009 7:18 am    Post subject: Reply with quote
Was going to just say no, but i figured that I'd elaborate a little bit.
Those are EFI injectors. I am a firm believer that anything can be made to fit so YES they could fit, but you don't want to do that.
In order to make them work you are going to have to rip out your entire CIS fuel system and spend a lot of time and money into fabricating a EFI system.
So if all that wrong is a leaky injector, then you should buy a replacement injector for like $30 instead of spending the $1,000-$2,000 on an EFI system.
1980 924 NA
1982 931
paulsmaroon924
PostPosted: Sun Nov 15, 2009 3:24 am    Post subject: Reply with quote
Cheers for that and thanks for elaborating on it. I really do appreciate it. That's cool I'll just get a replacement injector
Insane
PostPosted: Mon Nov 16, 2009 9:07 am    Post subject: Reply with quote
spending 1.5k on an EFI system is really a good deal
you can buy a set of Mercedes mechanical injectors, but for some reasons Porsche original work better.
talking about extra power: you will add NO extra hp just changing injectors. fairly you will add none installing EFI. you need to place turbo to get more hp or make your compression higher. but you'll need EFI for any of these options
Min
PostPosted: Mon Nov 16, 2009 1:46 pm    Post subject: Reply with quote
I disagree, you should see a increase in performance with EFI. Not a ton more power or anything, but you will see a increase.
Min
Insane
PostPosted: Mon Nov 16, 2009 5:51 pm    Post subject: Reply with quote
Min
I've got EFI installed on my car. so 125 hp on a crank - that's exactly what it shown on a dyno on 95 octane. and with the stock curve. on 98 octane it was something like 130~135 hp but with no air filter and with straight flow exhaust.
So yes, it gives a bit more power compared to untuned K-jet, but the real benefit is confidence and further tuning ability e.g. if you're installing turbo.
