BAE Manifold considerations
PostPosted: Fri Aug 28, 2009 5:03 pm    Post subject: BAE Manifold considerations Reply with quote
whoever designed the BAE manifold was a goose..
very tight fit with the alternator on the original side...pulleys and belts need playing with if this is your method ..
(ive got an aftermarket AC compressor on the otherside so cant move alternator there)
1979 NA
my Porsches Arse!!!
freakz
PostPosted: Fri Aug 28, 2009 5:51 pm    Post subject: Reply with quote
Mine has the alternator it on the non exhaust side.
So you must be able to mount the alternator on the other side.
Seems like the easiest fix.
Would exhaust heat cause problems with the belts?
924 Carrrera GT - Motec, GT35BB turbo
PostPosted: Fri Aug 28, 2009 6:07 pm    Post subject: Reply with quote
my AC compressor sits there.
not sure about radiant heat onto the belts??
1979 NA
my Porsches Arse!!!
Pieter
PostPosted: Fri Aug 28, 2009 6:36 pm    Post subject: Reply with quote
Seems like you're going to have more of a "conducted heat" issue than with radiated heat
Rich H
PostPosted: Fri Aug 28, 2009 7:20 pm    Post subject: Reply with quote
Turbo alternator mount would seem the obvious answer....
PostPosted: Fri Aug 28, 2009 9:48 pm    Post subject: Reply with quote
got a piccy? havent seen how the turbo mount sits
1979 NA
my Porsches Arse!!!
PostPosted: Fri Aug 28, 2009 10:29 pm    Post subject: Reply with quote
here ya go:
crap double post...
Insane
I guess you can reposition the alternator lower at the same side. you will need to machine new mounts for it.
And a heat shild! coz it must burn out the belt on a turbo application.
By the way,
can you measure the manifold? e.g.:
length
flanges diameter:
flanges angle:
manifold diameter:
I'm planning to have a turbo soon so looking for a good anifold design just like this one looks to be.
PostPosted: Fri Aug 28, 2009 11:44 pm    Post subject: Reply with quote
crap double post...
Well, at least you picked a good engine bay to show off
PostPosted: Fri Aug 28, 2009 11:45 pm    Post subject: Reply with quote
Scorpio, if you want to pursue the 931 mounting approach, I'm pretty sure I have all the extra brackets and stuff you'd need to add it.
Rich H
PostPosted: Sat Aug 29, 2009 12:11 am    Post subject: Reply with quote
Me too
PostPosted: Sat Aug 29, 2009 6:46 am    Post subject: Reply with quote
Cool Cool, does the NA head have the same mounting holes/ positioning for the brackets as the turbo head? i have no experience with the turbo setup and other limiting factors.. Bolt straight onto the 924?
1979 NA
my Porsches Arse!!!
PostPosted: Sat Aug 29, 2009 8:10 am    Post subject: Reply with quote
I'm pretty sure it does...as far as I know the blocks are pretty much identical. I'll go dig out the pieces I have, make sure I have everything, and maybe snap a few pix this weekend of how things are oriented on the 941 so we can compare notes. I also have a couple of bare 931 blocks we can look at.
Oh, and BTW, the engine is looking great!
PostPosted: Sat Aug 29, 2009 9:03 am    Post subject: Reply with quote
Scorpio, I have what you need:
931 AC + Alt mounting bracket assembly
What it looks like installed
Where it mounts on the block
I checked in PET, and the NA bracket for mounting the AC looks pretty much the same, but has a different part number from the 931, this due to the holes drilled in top of the casting for the small attached bracket that the alternator pivots on. There might be some other subtle difference as well to accommodate the tensioning arm on the left side of the assembled bracket. But it appears to me that the bolt arrangement for mounting both versions of the AC bracket is pretty much the same.
$35 + shipping for the bracket assembly shown in the photo (comes complete with serviceable bushings). You'd only need to source the three bolts to mount it to the block (one M10x70 and two M10x55 according to the illustration 902-06). PM me or email if you want it, should fit in a medium flat rate box no problem.
