Wiring Harness
Goto page Previous  1, 2
Which approach should I take for wiring up the UWB project
12-Circuit Painless
0%
 0%  [ 0 ]
14-Circuit Rebel Wire
25%
 25%  [ 1 ]
Use the like-new stock harness as-is
50%
 50%  [ 2 ]
Modify like-new harness with Painless breaker box
25%
 25%  [ 1 ]
Total Votes : 4
PostPosted: Thu May 21, 2009 4:06 am    Post subject: Reply with quote
Hey, you guys take your argument elsewhere. Can we stay on topic, please?
ic932
PostPosted: Thu May 21, 2009 4:09 am    Post subject: Reply with quote
Anyway, summer is comming. Time to pm me with a T34 style solution to the 94416V tensioner gamble....if you please?
ic932
PostPosted: Thu May 21, 2009 4:11 am    Post subject: Reply with quote
Sorry Dan. no argument intended.
Way off topic thou......
Raceboy
PostPosted: Thu May 21, 2009 4:17 am    Post subject: Reply with quote
ic932 wrote:
NO, son, you been promoting cowboy tactics fellla. Nowt wrong with that.
I'm not your son, are you even older than me? From the manners of yours I'd say not and you should drink less alcohol.
Sorry Dan.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
ic932
PostPosted: Thu May 21, 2009 4:41 am    Post subject: Reply with quote
[quote="Raceboy"]
Maybe, i'm 40 ...SON is a welcoming gambit. I'll happily call my grandad "SON".
PostPosted: Thu May 21, 2009 4:53 am    Post subject: Reply with quote
Back on topic, can anyone tell me what's not to like about Painless wiring harness? I've not been able to find any negative reports as to their durability or function...
I really like the idea of removing the stock fuse block, and splicing in a modern spade style block so that I can add circuit breakers...
PostPosted: Thu May 21, 2009 8:50 am    Post subject: Reply with quote
actually Dan i changed my mind, If you can figure out how to do a painless install while keeping all the stock dash switches and adding EFI then do it...just make sure you document everything so we can copy later on
p.s what was all that arguing about...gees that was from nowhere
1979 NA
my Porsches Arse!!!
PostPosted: Thu May 21, 2009 8:57 am    Post subject: Reply with quote
Yeah, that's an option too, I have all of the correct ends for whatever switch gear I might choose to keep, although I'm probably going to go with all toggle switches for everything...lights, hazards, turn indicators, wipers, the whole lot. In which case, Painless is more attractive.
Sheesh. Decisions, decisions.
PostPosted: Mon Aug 03, 2009 11:17 pm    Post subject: Reply with quote
Raceboy wrote:
EDIT: And if you want absolutely the best there is, walk away from relays and fuses and use something like this:
http://www.motec.com.au/pdm16/pdm16accessories/
Autospeed just ran a very nice overview article on MoTeC's new PDMs:
http://autospeed.com/cms/A_111402/article.html
Too bad these things cost so dang much!
PostPosted: Mon Aug 03, 2009 11:37 pm    Post subject: Reply with quote
Anybody have any insight or experience with ISIS Intelligent Multiplex Systems? http://www.isispower.com
Page 2 of 2
