Rocco R16V
Posted: Wed May 20, 2009 2:20 pm Post subject: SCCH Bump steer and ball joint lowering kits? |
I saw Gegge said,
| gegge wrote: | I would love a quick rack for faster steering! Maybe a kit to make a Golf Mk1 rack fit?
A bump steer-kit
A kit to raise the spindle and level the front a-arm when lowering the car i to improve chassi geomety and raise rollcenter. |
and I remembered SCCH make what he is looking for
Spindle raising ball joint "welding req"
http://scch-heads.com/viewpart.php?id=20
Bump steer kit for golf rack
http://scch-heads.com/viewpart.php?id=37
Those should work on our 924's, right? _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Wed May 20, 2009 3:37 pm Post subject: |
i'm interested ! group buy?  _________________ Supercharger and EFI kits
https://www.the924.com |
gegge
Posted: Wed May 20, 2009 5:38 pm Post subject: |
$695 for a ball joint and bumpsteer kit is a lot. Maybe worth it... _________________ Carl Fredrik Torkildsen
Posted: Wed May 20, 2009 7:53 pm Post subject: |
I purchased the Rennbay geometry correcting ball joint kit ($199) and the Elephant Racing bump steer adjusting tie rod kit ($360). Not quite as expensive and no welding required. However, it might be necessary to have the ball joint opening machined out just a touch because I think the correcting kit has a larger pin than stock, I still need to measure to verify. I'll post links and pix a little later. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed May 20, 2009 9:22 pm Post subject: |
no, you have the wrong link/wrong product...thats the bearing kit for the MK1...the bumpsteer kit costs $195.00 in wich case i'm very interested !
here is the link for the bump-steer kit.
http://scch-heads.com/viewpart.php?id=37 _________________ Supercharger and EFI kits
Posted: Wed May 20, 2009 9:31 pm Post subject: |
I think he was referring to the first link in the OP. The Gen I ball joint drop link kit listed at $500, the Gen II listed at $625. I don't think those ball joint kits will work on 924/944 arms.
The thing I should mention about the Rennbay is that I'm pretty sure it's only usable on the alu arms. 924/944 with steel a-arms would still have to figure out something on the ball joint. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu May 21, 2009 12:02 am Post subject: |
They look to me to bolt right into the steel arms. The question is whether you are comfortable with having the pin welded to your spindle. _________________ Toofah King Bad
