oil filter
Lizard
PostPosted: Mon Aug 19, 2002 6:54 am    Post subject: Reply with quote
hey guys anyone have a suggestion as too why my oil filter keeps coming loose it is really starting to bug me
Joes924
PostPosted: Mon Aug 19, 2002 2:32 pm    Post subject: Reply with quote
You got to have the right tool.
gohim
PostPosted: Mon Aug 19, 2002 6:53 pm    Post subject: Reply with quote
I never have problems with the oil filters coming loose.
Maybe it has something with the oil filters you are using, or the way that you are installing them.
Back when the cars were being made, there was some reportings of oil folters that failed. These filters turned out to be inferior generic branded filters that could not withstand the cold startup pressure of the cars that the Car Manufacturer's specc'd. The problem that I heard of was reported on Rabbits, Jettas, and 924s in the 70s. All of these cars use the same model of oil filter.
The other problem could be the way that you install your oil filters. Most oil filter manufacturers installation instuctions state that you should oil the gasket with fresh oil, then spin the filter on till the gasket makes contact with the mounting surface, then hand-tighten another 1/2 to 3/4 of another turn, and not to use a oil filter wrench.
On the 924, I sping the filter down by hand, then use a filter wrench to tighten another 3/4 to 1 turn.
No, I have never damaged the threads of the oil filter mount, and I have never had a filter come loose doing it this way.
Lizard
PostPosted: Tue Aug 20, 2002 6:23 am    Post subject: Reply with quote
I am using a K&N oil filter but it did it with a fram as well. and i am putting it on there tight
PostPosted: Tue Aug 20, 2002 7:38 am    Post subject: Reply with quote
Strange problem Liz. Maybe you need to rough up and clean the mounting surface on the block. Just kind of a common sense guess though - I never had the problem.
Other than that, maybe the threads are stripped somewhat?
[ This Message was edited by: smoothie on 2002-08-20 08:00 ]
Lizard
PostPosted: Tue Aug 20, 2002 8:05 am    Post subject: Reply with quote
nope the threads are fine have looked at them i am almost tempted to get some locktight on the threads
