Injector options??
PostPosted: Sun Apr 19, 2009 12:04 pm    Post subject: Injector options?? Reply with quote
Just upgrading to EFI whilst turning a NA into a turbo.
Dont have much idea on what injectors ill need to fit one of endwrenchs fuel rails...
I think my megasquirt 1 has the flyback board so can run low impedance(although its impossible to know off ebay whther theyre high or low impedance) will have to check with macb
Looking around 200hp so im guessing 400cc injectors?
Length of injectors etc??
any help appreciated...new territory for me
1979 NA
my Porsches Arse!!!
PostPosted: Sun Apr 19, 2009 1:03 pm    Post subject: Reply with quote
I run Ford Green Tops, they are 42# injectors, high impedence, and come in SVO Mustangs.
haroldk
PostPosted: Sun Apr 19, 2009 2:34 pm    Post subject: Reply with quote
SVOs came with 30# injectors with the early computers and 35# (or 36#, there's some controversy over which it was) with the later ones. The injectors Ford used in all the 2.3l Turbo applications were low impedance. The 30# injectors were green and the 35/36# injectors were brown. If you found 42# high impedance injectors in an SVO, they were installed by the owner.
Min
PostPosted: Sun Apr 19, 2009 2:36 pm    Post subject: Reply with quote
If your target horsepower is 200, looks like you will require about 29.4 pounds/hour which is 309 cc's, but since your doing it turbocharged, you need to add 10 percent approximately, so, thats 339.9 cc's, since you will probably not be satisfied with 200hp, you should have a bit of extra room for improvement, so, I'd recommend a set of 440cc bosch greentops which happen to be exactly what flosho also recommended, they are high impedance which simplifies tuning, and should be more than adequate. You can run them at a lower pressure initially if you like, so, something like 30 psi instead of 43.5, which will bring their flow down to 366cc/min so, they are about perfect.
here is a video of them being tested, so you can see what they look like and their spray pattern. http://www.youtube.com/watch?v=U01xCk6k-_Y
here is a set on evilbay http://cgi.ebay.com/ebaymotors/Bosch-42-lb-Pound-Fuel-Injectors-set-of-4-EV1-440cc_W0QQcmdZViewItemQQcategoryZ33553QQihZ015QQitemZ250383967726QQrdZ1QQsspagenameZWDVW
so, standard bosch 'ev1' injectors are what your looking for. I believe they have 14mm o-rings.
tuurbo
PostPosted: Sun Apr 19, 2009 9:44 pm    Post subject: Reply with quote
Looking around 200hp...
I think Min is correct that 200 HP might not whet your appetite.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Sun Apr 19, 2009 10:11 pm    Post subject: Reply with quote
thanks guys...
any more than 200hp will start to break things ....mainly my first and second gears
how are these ? all off mitsubishi eclipse turbo
http://cgi.ebay.com/ebaymotors/Eclipse-Talon-Stock-450cc-Black-Top-Fuel-Injectors-4g63_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a1Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem370189151481QQitemZ370189151481QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/DSM-550cc-fuel-injectors-Eclipse-Talon-Mitsubishi-Honda_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a1Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem360146766730QQitemZ360146766730QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
are they same size as the bosch ev1's? im guessing that a 14mm o ring can be just popped onto a injector with the smaller ring...same inner diameter?
1979 NA
my Porsches Arse!!!
PostPosted: Mon Apr 20, 2009 1:56 am    Post subject: Reply with quote
Personally am sus about buying S/H items like injectors unless you know their history and/or have them cleaned and flowed. If one is not up to scratch you run the real risk of a melted piston.
Agree with what others have said about selecting a Bosch EVI TYPE/SIZE injector, 14mm, especially if you are running Endwrench`s rail. 42 Lbs is a good choice, gives a little leeway and you only want to aim for a 80% duty cycle. Will add however that even if your MS is running the Lo Z flyback circuit, it is a better decision these days to use Hi Z injectors. Less current means less heat, more reliability and easier to tune.
Modern ball and disc type injectors will permit lower duty cycles and result in a smoother and easy to tune idle, for the same maximum flow rate, as compared to the green tops which IIRC are older pintle style. They also will not atomize the fuel as well as modern disc and multi orifice types. Running less than the designed fuel pressure to reduce flow is a bad idea as atomization will suffer at all duty cycles. May be able to tune around that slightly with X-tau, (if running it) but a waste of time for little benefit IMO.
There is some injector data in our links section here, and also here:
http://users.erols.com/srweiss/tableifc.htm
These are what I`m currently running. Good for idle, power and credit card.
http://www.racetronix.com/17113813.html
Min
PostPosted: Mon Apr 20, 2009 4:30 am    Post subject: Reply with quote
As long as your running enough pressure atomization will not be a issue. 30psi will work fine, your over exaggerating the issue quite a bit. I doubt you'd notice the difference between 43.5 psi and 30psi when tuning.
Min
PostPosted: Mon Apr 20, 2009 11:47 am    Post subject: Reply with quote
This is what I have:
http://cgi.ebay.com/ebaymotors/42-Injectors-Green-Top-Ford-Racing-SVO-M-9593-F302_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem350167560089QQitemZ350167560089QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
haroldk
PostPosted: Mon Apr 20, 2009 12:06 pm    Post subject: Reply with quote
Yeah, I'm not entirely clear why they put "SVO" in the title. If you're searching for injectors, a Mustang SVO won't cross-reference with any high-impedance injectors and there are better ways to find exactly the injector you want, anyway. I should ask my Ford parts guy if that part number is for a set of six or just singles. A lot of the time a FRPP part number will be a set.
That said, $260 shipped is a decent deal for 6 new injectors.
PostPosted: Mon Apr 20, 2009 12:41 pm    Post subject: Reply with quote
Interesting... I know if you search for Ford 42 lb/hr "green tops" thats what you will get..
In any regard, they have worked well for me!
haroldk
PostPosted: Mon Apr 20, 2009 8:18 pm    Post subject: Reply with quote
Yeah, I'm not saying they aren't available through FRPP, I'm just saying they never came in a Mustang SVO. While it's possible to find a Mustang SVO in the junkyard with 42# injectors, they'd likely be low impedance and they would certainly be owner installed. And given the kind of SVO owner that would install 42# injectors, an SVO with them almost certainly wouldn't end up in a junkyard.
So basically what I'm trying to say is if you want to buy 42# high-Z injectors you should search for that instead of an injector color or a car model. Bosch-style injectors are very common between makes and injector colors aren't standardized, even within a specific manufacturer.
Raceboy
PostPosted: Mon Apr 20, 2009 10:03 pm    Post subject: Reply with quote
It all depends on the price but if you are going to turbocharge the car and are a bit serious about it, I'd buy new Siemens Deka or Bosch EV12 pencil style injectors as these provide MUCh better atomization, control and precision over old EV1 style injectors.
They don't cost arm and leg either, brand new 630cc Dekas cost only around 60usd a piece.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Tue Apr 21, 2009 2:16 am    Post subject: Reply with quote
I would make friends with your local injector refurbishment store.
http://www.afi-australia.com.au/ <---don't know if they are any good, check them out thoroughly before spending your hard earned cash with them.
If you were here in the US, I would suggest Chrysler FWD Turbo cars from the eighties and nineties.
Here is an injector P/N cross reference for some of the Bosch injectors used on the Turbo-Dodge cars:
http://www.thedodgegarage.com/turbo_fuel.html
Also some others:
http://www.gnttype.org/techarea/fuelsystem/injflow.html
http://autospeed.com/cms/title_Injector-Flows/A_0102/article.html
http://vwmod.com/fuel.php
Either way, you'll want to have the injectors cleaned and inspected before putting them in your car. Otherwise you might have to make extensive repairs to the engine due to improper fueling.
haroldk
PostPosted: Wed Apr 22, 2009 5:35 am    Post subject: Reply with quote
For the US guys, I just heard back from my Ford Parts guy. The injectors Flosho has are available from Ford in sets of 8 only and were stock on the '99-'04 Lightning. They've got a bunch more listed here. All of them are high-Z and sold in sets of 8. I can actually get them for a lot cheaper, so I'll probably be going that route when I do an EFI swap and then selling the other 4.
