924guy
Posted: Wed Apr 08, 2009 10:48 pm Post subject: |
pretty cool stuff! i have a thing for custom dashes, in fact, im going to make a separate thread ... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Wed Apr 08, 2009 11:04 pm Post subject: |
924guy wrote: | pretty cool stuff! i have a thing for custom dashes, in fact, im going to make a separate thread ... |
wow just saw your thread..it lookkss amazing..would have taken alot of work... Ive found out the hard way how hard and fiddly a custom dash can be  _________________ 1979 NA
my Porsches Arse!!! |
Posted: Thu Apr 09, 2009 2:52 am Post subject: |
I saw the pics of your new rime there sharp and all though anly 4 lug
you sticking with the drums out back.. suppose itll be ok though not what i thought youd be doing. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Thu Apr 09, 2009 8:19 am Post subject: |
Joes924Racer wrote: | I saw the pics of your new rime there sharp and all though anly 4 lug
you sticking with the drums out back.. suppose itll be ok though not what i thought youd be doing. |
Theyll match the red with black highlights/ clolour scheme joe..
Maybe in a year or so ill jump across to disks....really have too much other tings on the car to do right now...it will be a weekend warrior not a daily driver so adjusting drum fade every 5- 6 months wont be an issue for me _________________ 1979 NA
Posted: Thu Apr 09, 2009 9:35 am Post subject: |
yea Ok jus goes along the lines in braking of You dont know what
your missin or maybe you do.. once you go disc.. drum fade is weird though not a big issue with you i can see that. I want to see that dash cover.. _________________ 1979 porsche 924 Na
Posted: Thu Apr 09, 2009 9:42 am Post subject: |
glue the vinyl straight to the dash..or a thin layer of cushioning foam? _________________ 1979 NA
Posted: Thu Apr 09, 2009 5:36 pm Post subject: |
Definatly a thin layer of foam. Like see if you can find something like 1/8 inch to a quater inch thick sheet foam... _________________ 1979 porsche 924 Na
Posted: Fri Apr 10, 2009 11:41 am Post subject: |
My dash is kind of beat up.. and it just acured to me that the center console is angled off to a side..Ill have to fix that .. my dash was a mess I filled the heater holes and reformed them with fiberglass resin and light weight filler.
Its my super dash fix.
Posted: Fri Apr 10, 2009 12:50 pm Post subject: |
joe you gotts do something about those wires...wire loom!  _________________ 1979 NA
Posted: Fri Apr 10, 2009 7:55 pm Post subject: |
I know its a big issue i was in a hurry to get the car back together at the time so then i bought my Amigo it blew up though.. Noo Im looking at this project like theres a palm tree on the side and its a project where time is not an issue I have alot of little projects on the car so im looking forward to doing the work. _________________ 1979 porsche 924 Na
Posted: Wed Jun 17, 2009 2:56 am Post subject: |
Rich H wrote: | Why not look at the cost of getting it properly flock covered (Not DIY the proper stuff!) |
This is very very interesting. Rich, what do you have against the DIY stuff? Curious if you (or anyone else) has any practical experience on this topic... _________________ erstwhile owner of just about every 924 variant ever made |
Rich H
Posted: Wed Jun 17, 2009 6:52 am Post subject: |
Alllegedly very hard - if not impossible, to get a good finish on large areas , not done it myself mind. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Jun 17, 2009 7:04 am Post subject: |
Here's a company that claims to have a product that works well for small and large objects like (among other things) dashboard:
http://www.donjer.com/products.htm
They have an air-assisted kit, which might make adhesion better. I'm sure the conventional electrostatic route would be best, but the problem is, I can't find any place here locally that does it, and their electro-static kit is more than I'd want to spend.
Might be worth some experimentation, given the low cost of entry... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jun 17, 2009 9:50 am Post subject: |
flocking??..sprayed on suede? _________________ 1979 NA
Posted: Wed Jun 17, 2009 11:06 am Post subject: |
Technically it's not suede, it's nylon or rayon fibers that end up creating a suede- or felt-like finish depending on the application process. What makes it attractive is the purported excellent anti-glare characteristics.
(Thanks to bass gt for bringing "flocking" to my attention). _________________ erstwhile owner of just about every 924 variant ever made |
