emoore924
Posted: Wed Mar 25, 2009 12:56 pm Post subject: Is there such a thing as a 14x7 5-bolt wheel? |
Toyo has a nice r888 available in 225/40 for a 14" wheel and I was thinking of dropping down to the smaller size.
I can think of a couple advantages including gearing change, lighter unsprung weight, lower center of gravity, they're even wider tread than the 225/40/15. Assuming a 14" wheel would fit over the brake calipers of course.
Only problem is that I can't seem to find any wheels that would work.
Ideas? I think this would put me into "go kart" territory for handling. |
Shurick
Posted: Wed Mar 25, 2009 4:10 pm Post subject: |
If you have a 5 lug brakes you can't use 14" rims. The brakes are too big for them. _________________ WBR, Shurick
'86 924S -- R.I.P.
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Wed Mar 25, 2009 5:14 pm Post subject: |
I use 7J teledials. With Toyo R888 205/50/15. I think you can't go much wider, because if your car is very low and negative camber (like all track cars) there is not much more room for wider tyers. _________________ 937 trackday car
Joined: 29 Jul 2001 Posts: 9080 Location: Royal Oak, MI, USA
Posted: Wed Mar 25, 2009 10:28 pm Post subject: |
More like it'd put you in the Spec Miata category of handling...  _________________ Vaughan Scott
emoore924
Posted: Sat Mar 28, 2009 2:10 am Post subject: |
| Quote: | | put you in the Spec Miata category of handling |
Not sure if "Spec Miata" is better or worse than now... Car handles pretty well as-is, so I would think it would handle and accelerate better with the smaller wheels with wider rubber than the 225/50/15's on 15x6 cookies that are on it now. Less unsprung weight for sure, maybe by 5lbs/wheel depending on wheels. That's a lot.
Can anyone confirm there is nothing in 14x7 that will fit over the 5-bolt calipers? Minilite? Panasport? Old Fuchs? Miata wheels? I thought something would fit... |
Posted: Sat Mar 28, 2009 3:01 am Post subject: |
I believe those are Spec Miata tires, is what I meant!  _________________ Vaughan Scott
