tuurbo
tuurbo
Posted: Wed Dec 10, 2008 5:11 pm Post subject: |
Hmmm. Maybe it's just BS. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Thu Dec 11, 2008 5:27 am Post subject: |
I believe the 3800's are related to the venerable small block chevy, so the swap would be fairly similar.
However, I'd be concerned with hood clearance and with the added weight of the supercharger and accessories, you wouldn't be far behind a Chevy LS2 small block that puts out more power. _________________ Stefan
Posted: Thu Dec 11, 2008 5:50 am Post subject: |
Recommended Reading List | On 20 June 2005, ideola wrote: | | Bob had his GN conversion on the dyno at Tweeks and was getting about 235HP and about 450ft/lb of torque as I recall, but he was having trouble producing anything beyond 16 PSI of boost, which is low for his setup. |
_________________ erstwhile owner of just about every 924 variant ever made |
tuurbo
Posted: Thu Dec 11, 2008 1:07 pm Post subject: |
Ok thanks Ideola - the second one is a good article - how do you find these? lol
The first one I checked out yesterday and it's long on hp but they don't say much what was modified or show pics. I'm going to try to contact the second article person, Bob Ward and see what I can find out.
I can sub out motor mount fabrication or even alter a cross member, but the steering? I doubt it. Maybe once I talk with this guy things can get clearer. But if it's a one off I could just as easily lose my shirt attempting it without the technical and tools background - subcontractors can do the work but most will want to be paid. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock.
Posted: Thu Dec 11, 2008 1:59 pm Post subject: |
| tuurbo wrote: | | Ok thanks Ideola - the second one is a good article - how do you find these? lol |
Good memory I met Bob back in 2005 at the Tweeks Fun Fest in Effingham IL, where I also met the Omaha Crew. Seeing a car like that in person makes it sorta hard to forget  _________________ erstwhile owner of just about every 924 variant ever made |
tuurbo
Posted: Thu Dec 11, 2008 2:39 pm Post subject: |
Yeah it looks like a monster.
I think with either the turbo or the supercharged version of this style/type of engine (about 3800 V6) engines, you'll have to pop a hole in the hood or make a 'cowl induction' or other monstrosity to cover up the bulge. But, who knows, I'd be doing it for the reliability of the engine and the availability of parts. And right now it's just a pipe dream until I nail down some questions.
The headlights were pretty interesting - the fact that he had two circular ones mounted nicely. I didn't care for the 'eyelid' look but I liked the powerful dual rounded lights. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
StienbargerR
Posted: Fri Dec 12, 2008 9:28 am Post subject: |
Tuurbo,
I dont mean to rain on your parade, but if you are doing an engine swap, it is probably best to use a V8. When I had my V6 conversion car, I did a lot of research on it, and many people have ruined their transmissions using V6's. It has something to do with the vibrations that GM V6's cause. If you look at what cars have the V6's, you will notice that most of them are connected to Auto transmissions, which are supposed to deal with this vibration alot better.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
tuurbo
Posted: Fri Dec 12, 2008 11:35 am Post subject: |
I like automatics. If I did a swap, I'd probably put in an automatic.
I haven't seen a successful V8 hooked up to our gearbox, with instructions and pictures anyone can follow, but I'd do it if I thought it'd work. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
mcadam1121
Posted: Fri Dec 12, 2008 11:56 am Post subject: |
yea do the v8 swap
i did a bunch of research on the 3800 swap and it wouldnt be that hard but a v8 would be easier
basically use parts from a camaro to do the swap
and then use a clucth from an 88 vanagon to mount to the torque tube if you got the 4spd _________________ The Ginger
77 porsche 924 Martini |
chad-tanner
Joined: 23 Mar 2008 Posts: 217 Location: New Madrid,MO
Posted: Fri Dec 12, 2008 12:37 pm Post subject: |
| tuurbo wrote: | | I like automatics. If I did a swap, I'd probably put in an automatic. |
The 3800 V6 will bolt to my trans without any other modifications,other than a different flywheel for the engine.
To be more clear,I'm talking about the GM 3800 & 3800sc-series I,II,&III.and not to be confused with the 3.8,that has the B.O.P. bolt patteren. _________________ 77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping. |
Posted: Sat Dec 13, 2008 7:42 am Post subject: |
| tuurbo wrote: | I like automatics. If I did a swap, I'd probably put in an automatic.
I haven't seen a successful V8 hooked up to our gearbox, with instructions and pictures anyone can follow, but I'd do it if I thought it'd work. |
Have you looked at http://www.porsche-hybrids.com ?? There is a ton of ways to skin that cat, lots of helpful people and many that post pictures.
Understand that any engine swap like this is not going to be "easy" If you're not comfortable doing the work yourself, find someone who is adept at welding and fabrication that is willing to not just slap a Chevy small block and turbo-action 350 transmission in the car and call it good. Look for a hotrod style shop that works on kitcars as well as hotrods. Check out their work and look for true oddball projects, those are the folks you want to work on your car.
If you select the proper parts (which are well detailed in a number of builds on that board) you can retain the 924 turbo/944 transaxle and torque tube solution. Plus if you post on the hybrids board you may find someone with a v8 swapped 944/924 that might be local and willing to lend a hand or at least let you oggle their ride a bit! _________________ Stefan
Posted: Sat Dec 13, 2008 8:49 am Post subject: |
Chad, what up with your Caddi project? _________________ Toofah King Bad
chad-tanner
Posted: Mon Dec 15, 2008 8:04 am Post subject: |
| Rasta Monsta wrote: | | Chad, what up with your Caddi project? |
Where do I start?
There has been some activity and many drastic changes in the overall plan,but I haven't taken any pics yet,because My vintage "1999" camera has flaked out.Although I'll get that taken care of very soon,I'm thinking about getting a camera that will also make nice videos.
My engine mounting system has underwent a major transformation,Including the Addition of rubber engine mounts,and more modification of the x-member,with the elimination of the bolts passing through it,making the lower portion of the mount,part of the X-member,With the Addition of many gussets and lots of nice tig welds,I'm very pleased with how it turned out.
I decided my oil pan was just plain silly,so the oil pan,pump,pick-up and pump driveshaft,have gone to the scrap bin.With outside help ,I have designed and constructed a proper dry sump oil pan,for a 3 stage dry sump oil system.I have collected many parts for this system,including the actual pump and a custom machined drive mandrel for the crankshaft,but like everything else, lots of things are missing and nowhere near completion.
Now for my carb system,It to has been eliminated from the plan.I'm now modifying the caddy PFI for use with this project.This became more practical after "tunercat" made software available for the "completely hacked" caddy ecm.
It's gonna take a little time,but i refuse to give up!  _________________ 77.5 Porsche 924/4.9L cadillac swap
