Rolling road Tuning
Rich H
PostPosted: Mon Aug 11, 2008 10:07 am    Post subject: Rolling road Tuning Reply with quote
Hey guys,
I'm looking at getting my MS'd 924 on a rolling road, primarily to sort the spark map. Now I understand the theory, set it up running at a certain revs and then advance it until it pings then back off a bit, is there anything else to it?
Ta
Rich
PostPosted: Tue Aug 12, 2008 1:33 am    Post subject: Re: Rolling road Tuning Reply with quote
Rich H wrote:
Hey guys,
Ta
Rich
Oh yes.
Thats the old school method. With 2 valves per cylinder, heron head, dished pistons and offset plug, our old school motors follow that train of thought to some extent.
The modern scientific rule is to run the minimum advance that the engine needs to produce maximum torque. This keeps you as far away as possible from detonation while generating the most power.
Really this does require a dyno with a brake that will load your engine, so as to tune the high map bins. Thats the most important yet critical area. Believe what Poms call a rolling road is just that, a pair of rollers, Find one with a brake and a competent operator. And one with MS experience if theres any such thing. A GOOD tuner will know what to do.
Heres some light reading that explains the theory:
http://www.ls1tech.com/forums/archive/index.php/t-254868.html
http://www.efi101.com/forum/viewtopic.php?t=3184
http://www.efi101.com/forum/viewtopic.php?t=2523
Roger
Rich H
PostPosted: Tue Aug 12, 2008 2:04 am    Post subject: Reply with quote
Will keep me amused for a few hours! Cheers RC!
Rich H
PostPosted: Tue Aug 12, 2008 2:15 am    Post subject: Reply with quote
So you`re at work eh?
Raceboy
PostPosted: Tue Aug 12, 2008 3:53 pm    Post subject: Reply with quote
On relatively low compression NA engines (less than 10:1) you can screw up the torque much before detonation occurs.
For every engine type, there's pretty spot-on basics that can be applied. I wouldn't even bother going to the dyno to tune 924 NA as you can tune it on the road to have 99,999% of the maximum torque in each load cell.
Dyno tuning is a must with highly built na engines that need to have camshafts adjusted etc.
On high-boost engines you also don't necessarily need to go dyno tuning because you almost never reach MBT before knock occurs. By high boost I mean 1,5+ bars.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Rich H
PostPosted: Tue Aug 12, 2008 5:26 pm    Post subject: Reply with quote
OK, so is it a matter of best guess on the curve then?
How about this, get a willing volunteer (Or other wise, you can drive darling), drive on the motorway as steady speeds while I tune, advance the ign curve until it looses power then back off a bit.
Repeat at every load site I can get to.... ??
Raceboy
PostPosted: Wed Aug 13, 2008 5:52 pm    Post subject: Reply with quote
You can't feel the power loss on the car unless it's 50 hp difference on 200 hp car or similar. It's a matter of common sense and experience and some reading.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Rich H
PostPosted: Wed Aug 13, 2008 6:23 pm    Post subject: Reply with quote
OK, I'll see what I can do.
