Matt Norton
Joined: 14 Apr 2006 Posts: 196 Location: Montour Falls/Watkins Glen NY
Posted: Tue Apr 01, 2008 5:13 am Post subject: |
| Eturbo924 wrote: | The other thing I was thinking about that car and its wandering front end... since the car was sitting for some time it is likely that the tire pressures were not correct. One tire being way under pressure will cause the issues you saw.... to some extent.
Also if the tires are not the stock size... which I think you noted the front end can tramline quite badly since the suspension is tailored to the stock tires.
Good luck in your seach.
Oh there was is a sweeeeeetttt 1984 in Maine. Black on black 5 speed with decently low miles. It was around $5K as I recall. Alas I just went looking for it and the add seems to have expired! DOU! |
defintely not stock wheels very nice looking thow. Tire presure, I think about it all the time on my own. Silly me. _________________ Red 1987 924S with plans for D Productions Kit
From American International Racing. |
Matt Norton
Posted: Tue Apr 01, 2008 7:53 am Post subject: |
Is there a site like this for the 928? _________________ Red 1987 924S with plans for D Productions Kit
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
sparky
Posted: Tue Apr 01, 2008 8:38 am Post subject: |
Have not read the entire thread, but here is my input..
The 928 is seriously an awesome car, maintenance.. well if something goes wrong, most parts are pretty much higher than any 924 part..
It will get you a ton of looks everywhere, if you can pick up an 87+ model.. The rear looks damn pretty!! The one in the garage is the Euro spec model and the power it gives was amazing.. I saw was because it is going through a beastly costly conversion
Just make sure that you give it a good once over before you buy, and if there is anything wrong look up the prices first..
They are cosy cars and seriously a ton of fun! IMO if you can get one in better condition it is the way to go, you will save a bunch by not having to fix up quite a few things.. _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
skrilla
Posted: Tue Apr 01, 2008 2:04 pm Post subject: |
ok i have a 1984 928s with a five speed ( just did the auto to man swap last month but thats another story) i am 6'2 and i fit very comfortably in it even though head room as pushed to the limit.
as for reliablity mine has done me no wrong in the past 8 years the only thing is trying to find the problem when you do have one! it now has over 250k miles on it on the original motor.
my fuel regulator went bad and i spent around 2k just trying to track down my problem and also the electrics can be a nightmare thankfully i have had none!!
plus like was mentioned before they are a heavy car meant more for long trips. here is a little tidbit you all might not know about them too they have a slight rear steering as well. since porsche took a lot of the technology for the 928 directly from racing this just kinda followed along. it was not intentional.
well thats just my two cents.
now since i am finished with the auto to manual swap i have a spare euro motor that is going to be rebuilt and supercharged!! that is this summers project i think (when the other ones are done!!) |
Matt Norton
Posted: Wed Apr 02, 2008 12:49 am Post subject: |
| skrilla wrote: | ok i have a 1984 928s with a five speed ( just did the auto to man swap last month but thats another story) i am 6'2 and i fit very comfortably in it even though head room as pushed to the limit.
I have the pics and information of how the the passive rear steering works in some PCA books. It is quite interesting.
How hard was it to do the auto to 5 speed conversions? _________________ Red 1987 924S with plans for D Productions Kit
Matt Norton
Posted: Wed Apr 02, 2008 1:26 am Post subject: |
Honestly, people think the 928 timing belt is scary? Well if breaks
Found this over on rennlist. show some pics of the front off exposing timing belt with instructions for for F.O.E.S. Honestly it doesn't look any worse then doing a 944 / 924S once you get it oppen. on the pluss side there is only one belt to tension versus two. Getting in there might be a little harder thow.
http://members.rennlist.com/pirtle/tbelt.html#remove_ten _________________ Red 1987 924S with plans for D Productions Kit
skrilla
Posted: Wed Apr 02, 2008 12:57 pm Post subject: |
well the timing belt is a pain in the arse but it is do-able you need a tensioning meter though they run around 500 if my memory serves me right. but mine is an 84 so only SOHC much easier
as for the conversion it took about 50 hours or so and thats tear down from the donor car included. plus it is a euro which makes supercharing the spare motor all the more inviting!! |
Matt Norton
Posted: Wed Apr 02, 2008 11:35 pm Post subject: |
Just found out about a red 83 automactic 928 localy. Just waiting for the dealer to get it in and set up a time to test drive it. _________________ Red 1987 924S with plans for D Productions Kit
Lizard
Posted: Sat Apr 05, 2008 7:04 am Post subject: |
For Khal et al,
They are being worked on, and will be in this year.
I just recieved my new 3 stage scavenge drysump pump with air oil seperator the other day so now I have to get to mounting that. _________________ 3 928s, |
dpw928
Posted: Sat Apr 05, 2008 7:11 am Post subject: |
Lizard,
Someone stole your cams. Noticed there are a set of 79's on ebay. Higher lift and longer duration so you can keep the boost lower.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
Lizard
Posted: Sat Apr 05, 2008 9:11 am Post subject: |
Dennis, they may work if they were for a 32V engine, but ALAS Porsche only saw fit to bring them in in 1985. And this engine is a 86 engine with 10:1 CR (true) _________________ 3 928s, |
dpw928
Posted: Sat Apr 05, 2008 10:53 am Post subject: |
Lizard,
Missed seeing the 32 valve heads. The front looks like mine will Sunday. Want to help change the TB?
78 928 5 sp Silver
Lizard
Posted: Sun Apr 06, 2008 10:50 am Post subject: |
lol how much of it are you doing Dennis?
total FOES? seals, gears, the works? or just belt and water pump?
I can do a belt and waterpump in 4 hours on these cars. Complex, not IMHO. However people do have trouble with them. _________________ 3 928s, |
dpw928
Posted: Sun Apr 06, 2008 11:28 am Post subject: |
Colin,
I have a new belt and waterpump. Since it was a nearly new crate engine when I bought it, I'm not sure which other parts I really need. On the 78 euro, I was in there three times within 550 miles. First I just changed the belt, then the WP went south after 50 miles. The next time I changed everything except the front main seal and guess what blew out (son over rev'd when cold)? Yep the front main seal.
Was going to open it up tonight but "she who must be obeyed" had other plans, so now it's getting torn down tomorrow. I'll take inventory, order the other parts and finish it off next weekend. BTW the last time I did the euro it was about 4 hours but I didn't have to replace anything except the belt and main seal.
78 928 5 sp Silver
