'83 924 N/A got turbo (Updated pics on page 12)
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13  Next
Raceboy
PostPosted: Fri Mar 28, 2008 5:16 am    Post subject: Reply with quote
Today I measured the 0-100 kph performance on my 924 with Driftbox by Racelogic. It's GPS based like more expensive V-Box but doesn't have realtime telemetry, instead it saves data to memory card.
Sooo, 0-100 kph was 6,1 seconds with 0-60 kph being 3,0 seconds. That shows that there was basically no traction and it felt like that also : wet road with occasional snowy islands on the tarmac.
Wheels were 16" BBS RS with 225/50 Blizzaks on them, 4 speed 924 gearbox (5speed is out right now for LSD install).
But, I'm pulling it out of my a$$, but I'd expect realistically around 5,2-5,4 seconds with 5speed box, non-slipping clutch, clean air filter (current one is.....shitty?) and better traction.
Still, pretty good!
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
924inMN
PostPosted: Fri Mar 28, 2008 6:27 am    Post subject: Reply with quote
My head is swimming, so much information. I can see I'm going to have quite a bit of studying to do.
PostPosted: Fri Mar 28, 2008 7:37 pm    Post subject: Reply with quote
heheh! ask a simple question....
As for studying, go get a copy of "Maximum Boost" and read it at least twice.
And if you get stuck, we're here for ya!
PostPosted: Fri Mar 28, 2008 8:16 pm    Post subject: Reply with quote
Thanks to Raceboy heres a link to a cheap copy.
http://www.tud.ttu.ee/~t041509/Maximum_boost.pdf
Roger
804kid
PostPosted: Fri Apr 04, 2008 8:38 am    Post subject: Reply with quote
ok i finally welded together my intercooler piping and exhaust side, all the plumbing is done and there are no leaks. i started the car am im scared to run it becase i know im supposed to enrich the fuel ratio but i dont know how much, and other then that i think everthing should be okay, im running 8 psi. oh and i pulled a 931 head from a junk yard. would it be a good idea to bolt that up wtih a new gasket? would i need to do anyything else?
PostPosted: Tue Apr 15, 2008 3:10 am    Post subject: Reply with quote
Here's yet another reference to fuel enrichment for CIS that I dug out of my bookmarks. Note that this individual is using two injectors between the IC and TB, controlled by an aquamist MF2 unit.
http://www.audifans.com/pipermail/quattro/2000-August/000799.html
drwal
PostPosted: Tue Apr 29, 2008 8:15 pm    Post subject: Reply with quote
hi
i am also going to install turbo in my 924 n/a.
My question is:
is it possible to mount the turbo charger on the other side ? there where is exhaust ? or there is no space for it ?
P924 2.0 '77 -> 125 PS sold
P924 2.0 '80 -> 125 PS = now on parts
P931 US '80 -> big project
P928 S4 '87 -> 320 PS
Pozdrawiam wszystkich posiadaczy ! www.924.pl
PostPosted: Tue Apr 29, 2008 9:09 pm    Post subject: Reply with quote
Yes, this has been done at least once or twice by members here...may take some searching to find the threads...
PostPosted: Wed Apr 30, 2008 12:05 am    Post subject: Reply with quote
You can. . .see e.g., Porsche 937 and 951. If you look at this pic carefully, you can see the exhaust setup. It splits after the header, with one side going to the wastegate, and the other side crossing under the bellhousing to the turbo.
PostPosted: Wed Apr 30, 2008 12:25 am    Post subject: Reply with quote
DUH!!! [beats self over head]
Look at the very first post on this 11-page thread. Also here.
PwrGTOGuy
PostPosted: Wed Apr 30, 2008 6:09 am    Post subject: Reply with quote
nevermind
PostPosted: Tue May 06, 2008 7:01 pm    Post subject: Reply with quote
was just reading through this thread and saw a payout of my electric supercharger that went unargued!!... hahhaa.. cant be arsed arguing right now to busy trying to sort out my turbo and engine rebuild....
1979 NA
my Porsches Arse!!!
drwal
PostPosted: Wed May 07, 2008 5:28 am    Post subject: Reply with quote
thnx all for replays
now it is time to go back to my garage
vemser
PostPosted: Sat May 10, 2008 2:31 am    Post subject: Reply with quote
Raceboy, can you post new your ignition picture, like this one - http://porsche-foorum.ee/album/albums/userpics/10026/normal_16x14spark.jpg
How much kpa on idle?
vemser
PostPosted: Sat May 10, 2008 2:38 am    Post subject: Reply with quote
Also interesting for me, your log and msq files)
Page 11 of 13
