Posted: Sat Mar 29, 2008 7:20 pm Post subject: Speed bleeders in Oz |
Man... finally got around to installing speed bleeders and braided lines I bought ages back... except one pair of the speed bleeders are too big - doh. I bought em off ebay, but prolly over a year ago.
Anyone in Oz know where they can be picked up locally? Hoping to get the car moving and stopping this weekend...
Cheers, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Ozzie
Posted: Sat Mar 29, 2008 10:31 pm Post subject: |
IIRC they are 8 x 1.25mm.
A specialist brake shop should have them. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Sat Mar 29, 2008 11:27 pm Post subject: |
7x1.0 on the rear and 6x1.0 on the front - at least for my 4-lug setup...
http://www.speedbleeder.com/size.htm
Ta, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Ozzie
Posted: Sun Mar 30, 2008 8:05 am Post subject: |
Your chart says the other way around. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Mar 30, 2008 8:16 am Post subject: |
Yes, correct! _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Sun Mar 30, 2008 9:55 am Post subject: |
Is there anything special about these?
They look like common bleed nipples to me? |
Ozzie
Posted: Sun Mar 30, 2008 2:15 pm Post subject: |
They have a one way valve in them.
Loosen off a fraction, connect a hose and bottle to the end to catch the fluid and pump the pedal to bleed the brakes. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Mar 30, 2008 3:29 pm Post subject: |
Was thinking they had an internal valve but wasn`t sure.
You still have to loosen them off but makes it a one man job rather than a family affair. PITA if you have a pit or hoist.
Roger |
Posted: Sun Mar 30, 2008 7:00 pm Post subject: |
FWIW, for the fronts I'd suggest the SB7100S model. I got the standard ones, and whilst they seem to work fine are a little longer than required.
69 911 |
