Posted: Fri Mar 28, 2008 9:21 pm Post subject: Reusing a cracked turbine housing? |
This question came up in a recent thread, but didn't garner any direct answers, so I'm going to repost here.
I have four complete K26 units. One of them (a series I) has been rebuilt and is sitting on the shelf, either as a last resort option for the UWB project, or hopefully as a replacement for the 941 when the time comes to rebuild its turbo.
Of the other three, two are Series I and one is a Series II. All three of them have cracked turbine housings, and two of them appeared to be in excellent condition before I disassembled them (i.e. very little shaft play, compressor and turbine fines in excellent shape, etc.). Here are some photos of one of the turbine housing after being cleaned up. All three of the turbine housings have cracks in the exact same location.
My question is whether these turbine housings can be safely reused without further repair. I realize it's probably not ideal, but given the relative scarcity and uniqueness of this style of turbine housing, if cracked units can't be reused, it really exacerbates the scarcity problem. Smoothie indicated in the aforementioned post that this seems to be a common problem to both Series I & II, and also that he wasn't sure if it would affect performance or operation, which is why I am asking about the feasibility of reusing these.
In the meantime, if anyone has an uncracked K26 turbine housing you're willing to part with, please contact me ASAP. I'm in the market, as I urgently need a solution for my UWB project. _________________ erstwhile owner of just about every 924 variant ever made |
emoore924
Posted: Sat Mar 29, 2008 12:28 pm Post subject: |
| PM me. I might have an extra K26 housing that's crack free. In your message, tell me how I'd find a crack like that without disassembling the turbo. |
462avi
Joined: 15 Sep 2006 Posts: 149 Location: Hollister, California
Posted: Sat Mar 29, 2008 12:54 pm Post subject: |
My opinion would be no. The turbo I removed from my car had similar cracks in the hot side housing. The crack when heated will expand into the turbine opening and damage the turbine.
Geoff _________________ 2005 C230K
2002 grand cherokee with 4.7L |
Posted: Sat Mar 29, 2008 3:39 pm Post subject: |
According to Majestic, those cracks are weldable. _________________ Toofah King Bad
Posted: Sat Mar 29, 2008 9:55 pm Post subject: |
| emoore924 wrote: | | tell me how I'd find a crack like that without disassembling the turbo. | I don't think there's any way to check for cracks with the unit assembled. On all three of mine, the cracks appear in exactly the same location as in the photographs in my post, right at the start of that slot in the casting. Even if you could rotate the wheel, peer in with a flashlight, etc., I would expect it to be very difficult to see, particularly with the usual carbon buildup. Nevertheless, PM sent.
| 462avi wrote: | | The crack when heated will expand into the turbine opening and damage the turbine. | Yes, that is exactly the concern that John (of Majestic) and I discussed.
| Rasta Monsta wrote: | | According to Majestic, those cracks are weldable. | Are you referring to Majestic Turbo in TX? With whom did you speak? They have several of my turbo bits in their possession at the moment. I've been dealing directly with John Walzel, and although I didn't ask about welding, he didn't volunteer it as an option.
In the meantime, I've done some further digging, and I've uncovered a new mystery. Maybe y'all can help out with this:
All of my turbine housings are part number 5326-101-6365. However, one of the sources I contacted did some research on the K26 and came up with a Turbine Housing 5326-100-6329 number being mated with the same compressor housing that comes with all of my K26 turbos. I haven't seen that number anywhere, not even in Nick's voluminous post on KKK part numbers.
What I find interesting is that according to Nick's post, the 5326-100-6328 turbine housing is known to be for the 924 Carrera GT, and the 5326-100-6330 turbine housing is known to be for the 924 Carrera GTS/GTR. The 6365 number is listed as the stock turbine housing for all makes and models of "normal" 924 Turbos, regardless of year or market. So, I'm wondering if maybe the 6329 part is an improved, superseded part for the obviously inferior 6365 turbine housing. Thoughts? Verification? _________________ erstwhile owner of just about every 924 variant ever made |
KlaasyT
Joined: 20 Jul 2006 Posts: 25 Location: Ontario Canada
Posted: Sun Mar 30, 2008 10:08 am Post subject: |
I had my cracked housing welded when I replaced the bushings. That was 10000 miles ago, so far no issues. The welder was very experienced, and knew what he was doing. I'm sure more have done the same.
Clarence _________________ 81 931 Minerva Blue
72 911t Irish green
84 911 Carrera Targa sold
72 911t rs look project
71 911e rusty future project |
462avi
Posted: Sun Mar 30, 2008 1:24 pm Post subject: |
I know cast iron can be welded. The real question is, is it worth the money. I had my old/bad housing welded by a friend who wanted to try out a new type of rod. It still needs to be machined but it looks pretty good. I don't think it is a flawed design necessarily, but on other hot side housing there is a longer approach to the turbine. Ours seems to neck down very dramatically.
462avi
Posted: Sun Mar 30, 2008 1:25 pm Post subject: |
I know cast iron can be welded. The real question is, is it worth the money. I had my old/bad housing welded by a friend who wanted to try out a new type of rod. It still needs to be machined but it looks pretty good. I don't think it is a flawed design necessarily, but on other hot side housings there is a longer approach to the turbine. Ours seems to neck down very dramatically.
Posted: Mon Mar 31, 2008 8:57 am Post subject: |
This weekend I picked up a 6411 K26 from Vaughan that came off of an Audi. A couple of cool things about this unit is that it has a water jacket in the bearing housing, and it is a direct fit replacement for the stock 931 bearing housing (except for the bracket that attaches to the block...but that's another story).
More importantly, the turbine housing is almost identical to the 6365 turbine housing from our K26 unit, except that it has a four-bolt flange, and a slightly larger throat. The exhaust connection on the turbine housing has exactly the same bolt pattern as the primary exhaust pipe, and except for the flange insert on the 931 pipe (nothing a little machining couldn't solve), it is a direct fit
This is really the first time I've had a comparably sized 4-bolt turbine housing in my hand. After looking at things a bit, my buddy Larry asked why we couldn't just weld on some additional material to the stock ex manifold to convert it over to 4-bolt. It appeared to me that the 6411 turbine housing would bolt right up and could be mated to all of the other K26 components. Having said that, if we could add add'l material to make a flange that looks something like this...
...why couldn't we just convert over to a modern Garrett???? Am I crazy, or does this look completely doable? I've asked my welder and he thought it would be no problem, maybe 2 hrs max worth of work. _________________ erstwhile owner of just about every 924 variant ever made |
john h
Joined: 06 Nov 2002 Posts: 827 Location: Wellington New Zealand
Posted: Mon Mar 31, 2008 9:46 am Post subject: |
personally I wouldn't worry about the crack in the hot side. The turbo I've been running on my race/ road car for many years (since 1992) had a crack similar to your photo's when we put it on and it's now run almost 16 years and over 100,000 miles with out the crack causing a problem.
My view and my Mechanics was it was downstream of the motor and if it created a problem it would just destroy the hot side and in the very worst case it might throw stuff though the inlet side - but as I've an intercooler between the turbo and engine which will sort of filter out a lot of the crap and not much will get through to takeout the motor. And it if does go through the bottom end of the motor - no problems as I've about 5 or 6 short blocks all setup ready to swap over. _________________ Remember a Porsche is not just for Christmas,
if you take it to pieces slowly it can provide anguish all year long! |
emoore924
Posted: Thu Apr 03, 2008 11:54 am Post subject: |
Ok, here's what I found out.
I have two spare turbos sitting on the shelf. One I'd consider to be parts only because of excessive shaft play -- rebuild possibilities only. The second I would consider to be a plug-n-play -- in good shape, no problems.
Both have cracks at exactly 3 o'clock when you hold the turbo so the KKK triangle is at high noon. You can see the crack in the housing in front of the impeller, and they extend down into the housing.
That being said...,
The sort of good news:
The turbo that's in worse shape looks like it has had the crack for a *really* long time. The edges are eroded and rounded down, sand blasted almost. It is dull and open. Clearly, it had been run a long time like this without problems. I think this turbo eventually failed because the shaft bearing developed excessive play and the impellor finally hit on the housing -- I doubt that had anything to do with the crack but I'd have to disassemble to know for sure what the race looks like.
The sort of bad news:
The other housing in good shape also has a crack at exactly 3:00 as well. It is newer and sharper and more pronounced, but it doesn't seem to affect the runout of the shaft at all. So, while it is cracked too...
The other good news:
I'm not sure how much it matters.
I have another turbo coming off a running car in the next few days. The car ran really well with no noises or problems. If it has a crack too (I'd expect that it would), I'd start to believe the "don't worry about it" perspective. If it has no crack, I'm not sure whether that would be conclusive either way.
If you want pickies, please LMK and I'll send what I can. |
emoore924
Posted: Sat Apr 05, 2008 6:22 am Post subject: |
Update: The turbo that came off the car doesn't seem to have the 3 o'clock crack. Looks good. I haven't checked really close (bright light, magnifying glass...) but I don't see anything upon a cursory inspection.
Shaft play is minimal too. Another spare turbo for the spare turbo shelf. |
Posted: Sat Apr 05, 2008 7:13 am Post subject: |
If you want to be sure, have it magnafluxed. _________________ Toofah King Bad
emoore924
Posted: Sat Apr 05, 2008 2:47 pm Post subject: |
Rasta, most of the cracks I've seen probably don't require magnaflux to find them. They're so big you could stick a quarter in there sideways. But certainly a great idea if you're not sure something is there. I'm not suspicious enough about the turbo I just took off to spend the $ to flux it. It ran well enough on the car, so whatever the crack situation, it'd probably run well enough again.
And ALL the cracks I've seen are at 3 o'clock. So when they're there, they're easy to find. |
Posted: Sat Apr 05, 2008 10:32 pm Post subject: |
I'd put it in the blast cabinet first. On one of mine, the cracks couldn't be seen until the carbon buildup had been removed. Also, if you look at the pix in my original post, they do form cracks in other areas besides the usual "3:00" location. I saw one that had a crack longitudinally in the groove right where the scroll begins (also at the 3:00 location). _________________ erstwhile owner of just about every 924 variant ever made |
