Mounting Mudflaps
dash16
PostPosted: Mon Mar 10, 2008 8:06 pm    Post subject: Mounting Mudflaps Reply with quote
Just purchased some mud flaps from Eturbo924. He was very responsive in communication and the delivery was quick.
Anyways, I need help mounting these to my car. Did porsche offer a template that shows you exactly where to drill?
I really don't want it installed so-so close-enough. I want the holes drilled exactly where it needs to be, as if it came straight from the factory.
Please share with us your personal experience and advice on *properly* mounting these sexy beasts.
Thank you.
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
fezza575m
PostPosted: Mon Mar 10, 2008 10:07 pm    Post subject: Reply with quote
Hey
These are the mud flaps i just recently ripped off my car for the new CGT body kit
Not to sure if they are genuine or not.....so in fact this mighten be much help to you at all...but heres a pic of mine and you can see where the holes are drilled
in the second pic you can see there is 4 holes....3 are obvious and their is one up the top which ou can only just see
I hope this helps
Cheers
Red 1977 Porsche 924 CGT...THE MORPH IS COMPLETE
dash16
PostPosted: Wed Mar 12, 2008 9:32 pm    Post subject: Reply with quote
I appreciate the effort on your posting pics of those old mudflaps.
Unfortunately, that isn't going to help me align my flaps correctly.
Has anyone here actually done this themselves?
Or how would a skilled body shop do it?
Thank you.
STUTTGART PREVAILS
PostPosted: Thu Mar 13, 2008 2:13 am    Post subject: Reply with quote
I still haven't reinstalled mine, so have easy access to measure where the holes are.
I'm in the middle of reassembling my Jeep engine, but with some luck will remember to measure..
PostPosted: Thu Mar 13, 2008 2:19 am    Post subject: Reply with quote
*click*
PostPosted: Thu Mar 13, 2008 10:31 am    Post subject: Reply with quote
Ok, hopefully tomorrow..
I started to measure, but then realized it was going to take more than a few minutes, and involve more than a few simple measurements. I'll have to make a template because of the curved surfaces. I'm also missing the uppermost hole, and I believe it's gone on both sides (they got "repaired" along with quite a few more serious defects two years ago) - so also have to locate where that hole should be.
The Jeep engine's coming together at least -
PostPosted: Fri Mar 14, 2008 11:52 am    Post subject: Reply with quote
Mudflap mounting template: 5 pics with instructions starting here -
<click>
<click> for large pic of the template (for readable measurements) -
dash16
PostPosted: Mon Mar 24, 2008 5:59 pm    Post subject: Reply with quote
wow smoothie, thank you very much. I nominate you for the most helpful forum member award.
I will be attempting to use the template you set out tomorrow.
STUTTGART PREVAILS
secretsquirrel
PostPosted: Tue May 10, 2011 5:26 am    Post subject: FRONT mudflaps ! Reply with quote
Hya guys, haven't been around much recently, the ole ladies getting some love and being touched up with some red paint.
Scrounging around in a scrap yard the other day, I found some original rear mudflaps that'll look cool, and give a lift to the styling to the back. (As per Rastas schematic.)
...got me thinking tho'.....I've never seen any front ones ?
Anybody know of anything that'll fit ?
'83 924, absolutely straight, original, low miles...just another sad bloke with a fatal, expensive, addiction to old cars....the list is long and boring !
McGyver
PostPosted: Fri Mar 22, 2013 8:03 am    Post subject: Reply with quote
One more time On that picture in manual they showed 5 screws M6 but write it should be just 4 of them. I had to install my mud flaps lying around but they don't have any of screws so I want to put new one back in stock places. And mount them in rubber with some black silicone sealant which should be strong enough. Anyone have photo how stock mud flap should look like with screws?
931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible)
