S2 engine performance improvement
Goto page Previous  1, 2
Lizard
PostPosted: Fri Nov 23, 2007 2:00 pm    Post subject: Reply with quote
Very good book, though I found it for purchase for about $20 cdn locally, still need to get it though.
3 928s,
bruce76-924
PostPosted: Sat Nov 24, 2007 12:16 am    Post subject: Reply with quote
Thanks for that Raceboy!! Another good book on the subject is "Turbochargers" by Hugh MacInnes, published by HP books.
Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
PostPosted: Sat Nov 24, 2007 3:19 am    Post subject: Reply with quote
i'm reading it...will post when i have made my decision on what diameter and IC will use.....and explinations for that.
PostPosted: Mon Nov 26, 2007 12:35 am    Post subject: Reply with quote
ok...got it...i read the intercooling section and i have this until now:
From the calculations it resulted to me that if i want an IC good for ~250 BHP using medium density and 10" long cores(i only have access to this type), the IC core will have to be 35cm long / 25cm tall and 7.5cm thick. I have also decided on the design of the i/o caps but i'm still thinking about using 2" or 2.5" pipes.
pushing 250 BHP with 2" pipes would result in ~290 ft/sec intake gas speeds while using 2.5" pipes would give one ~190 ft/sec gas sepeeds.
PostPosted: Mon Nov 26, 2007 6:02 am    Post subject: Reply with quote
Does that allow for the wall thickness of the pipes,? Usually 2mm for ally and 1.2-1.6 for stainless or mild steel. So the ID is 3 or 4 mm less.
Roger
PostPosted: Mon Nov 26, 2007 7:44 am    Post subject: Reply with quote
no the calculations refer to the usefull area....however the 2mm do not affect the flow in such a dramatic way...what i was interested more in was the difference between the 2" and the 2.5" profiles
PostPosted: Mon Nov 26, 2007 8:11 am    Post subject: Reply with quote
Not being critical but a quick calculation shows over 17% difference in cross sectional area and therefore flow between 48mm and 52mm. May as well work it out realistically. Anyway, what size pipes are you going to use?
Roger
PostPosted: Mon Nov 26, 2007 8:50 am    Post subject: Reply with quote
2.25" like I suggested
PostPosted: Mon Nov 26, 2007 5:53 pm    Post subject: Reply with quote
match it to your throttle body...
Leadfoot
PostPosted: Tue Nov 27, 2007 1:52 am    Post subject: Reply with quote
hmm...this sounds right....whats the 931 S2 TB diameter ? 52mm ?
PostPosted: Wed Nov 28, 2007 9:41 am    Post subject: Reply with quote
Raceboy or anyone else. Dont suppose you can give us a link to Corky Bell`s book "supercharged"?
Thanks,
Roger
Raceboy
PostPosted: Wed Nov 28, 2007 4:10 pm    Post subject: Reply with quote
Thanks,
Roger
Sorry, don't have the link for it.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Dec 28, 2007 6:17 pm    Post subject: Reply with quote
does anyone have some info on the 931 head flow numbers? max gas speed trough it...? i remember there was some talk about this a while ago..
Page 2 of 2
