isuras2
Posted: Tue Oct 09, 2007 10:40 am Post subject: Battery Cable |
I am going to change my battery cable, the one from battery to starter. Anyone know how long that cable is? Also, any easy advice as how to clean the grounds above the fuse panel?
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Tue Oct 09, 2007 11:39 am Post subject: Re: Battery Cable |
| isuras2 wrote: | | any easy advice? |
No!
My hands must be bigger than other folks' around here, but I removed the driver's seat and laid under the steering wheel for a good amount of time, and couldn't even imagine unplugging any of those grounds, much less plugging them back on. The best I could do was clumsily smear everything in the area with conductive grease.
Good luck! _________________ Toofah King Bad
berenlotr
Posted: Thu Oct 11, 2007 7:10 am Post subject: |
i managed to switch every connector on those ground wires but it was a PITA. used long needle nose pliers to get the connectors off. i removed the steering wheel and laided down on the the seat to get at them. lol gl _________________ 1979 924 N/A |
