Druman
Joined: 19 Mar 2007 Posts: 419 Location: Middleport, Ohio
Posted: Thu Sep 27, 2007 7:43 am Post subject: Is it my thermostat? |
For some unknown reason my temp guage never goes past 2 bars. If I remember correctly, normal temperature is between 2 and 3 bars, but mine usually rides somewhere between 1 and 2, even if I've had the car on the road for an hour and let it idle for 10 min. Anyone know if the thermostat is the culprit?
TIA
7osh _________________ 87' 924S non-sunroof (Red) 45K miles
85' 944 "early" NA (Red) 130K miles
PORSCHE pisses excellence... |
Posted: Thu Sep 27, 2007 11:31 am Post subject: |
Buy a new o-ring, and pop it out. The temp is stamped into the t-stat, at least that was you can tell if someone put a cooler one in there. _________________ Toofah King Bad
colin
Posted: Thu Sep 27, 2007 1:45 pm Post subject: |
my temp goes up to the 3rd bar, then the car vibrates a little bit for about 5-8 seconds, and then it drops down to the first bar, any one know whats up with that? _________________ 1979 924 parting ways
1987 924S
1987 parts car |
Posted: Thu Sep 27, 2007 2:07 pm Post subject: |
You have a fan mount loose or a fan failing? _________________ Toofah King Bad
Druman
Posted: Fri Sep 28, 2007 3:40 am Post subject: |
Well, when I got the car it was fine, but now it's running cool. _________________ 87' 924S non-sunroof (Red) 45K miles
