Lowering the front of my 924 2.0
PostPosted: Sun Aug 12, 2007 5:13 pm    Post subject: Lowering the front of my 924 2.0 Reply with quote
I want to lower the front of my 924 2.0 (budget) track car.
In Holland I can only get lowering springs up to 20mm lower.
But I want to go lower. A few questions:
- Will 944 turbo spings be lower ?
- Can I use stock beetle springs ?
- How low can you go ?
PostPosted: Sun Aug 12, 2007 5:41 pm    Post subject: Reply with quote
Could you use something like this? -
<click>
They'd lower while keeping you well within a budget, + be easy to implement.
scottc
PostPosted: Sun Aug 12, 2007 7:51 pm    Post subject: Reply with quote
944 springs will turn it into a monsta truck!
PostPosted: Sun Aug 12, 2007 9:15 pm    Post subject: Reply with quote
So how exactly are these things...
s'posed to work?? Do you just use them to compress some of the coils in the stock springs? And then adjust the rear ride height?
PostPosted: Mon Aug 13, 2007 1:49 am    Post subject: Reply with quote
No, I don't like that solution, I rather cut of a few rings of the spring.
PostPosted: Mon Aug 13, 2007 1:53 am    Post subject: Reply with quote
Why not buy the correct lowering springs from some other country?
PostPosted: Mon Aug 13, 2007 4:45 am    Post subject: Reply with quote
Do they exist lower then -20mm ?
PostPosted: Mon Aug 13, 2007 5:06 am    Post subject: Reply with quote
There are 3 choices that I know of, they are 200lb, 220lb, and 250lb.
The 220lb (which I'm using, retain the stock height (which is what I wanted)).
The 200lb and 250lb allegedly lower by something in the range of 1.25"(32mm) to 1.5"(38mm).
A Search for all terms on 200 250 springs lower brings up a few relevant topics.
Here's one - http://www.924board.org/viewtopic.php?t=17067 , but look through them all.
PostPosted: Mon Aug 13, 2007 5:16 am    Post subject: Reply with quote
I've never heard of these guys....
http://www.autodirectsave.com/product/list/1980/Porsche/924/Suspension/Coil_Overs
!tom
PostPosted: Mon Aug 13, 2007 7:44 am    Post subject: Reply with quote
Cutting the springs will increase the spring rate.
This might be the ideal solution for you, because you may want to increase the spring rate for your track car. You can both lower your car and increase the spring rate at the same time by cutting your springs.
Be careful -- I doubt this procedure is reccommended by many, since a subsequent spring failure might be uncomfortable. Also, measure several times before you cut to make sure you end up with your desired lengths -- different if you're redneck racing (not that there's anything wrong with that), or the same if you're roadcourse racing.
78 924 NA
5-lug
jazz guy
PostPosted: Mon Aug 13, 2007 9:11 am    Post subject: Reply with quote
Here is another inexpensive coilover kit, and Paragon is a GREAT place to use for parts.
http://www.paragon-products.com/ProductDetails.asp?ProductCode=944ARHK%2DR
I am getting this kit for my car.
Cheers, Brian
PostPosted: Mon Aug 13, 2007 10:52 am    Post subject: Reply with quote
I see smoothie linked to my thread, and I went with the 250# weltmiesters, and it certainly lowered my car some, but I would even say not low enough. However it does sit pretty nicely:
http://i73.photobucket.com/albums/i211/flosho924/931%20Exterior/DSC05184.jpg
http://i73.photobucket.com/albums/i211/flosho924/CIMG0470.jpg
Chrenan
PostPosted: Mon Aug 13, 2007 11:02 am    Post subject: Reply with quote
Agreed, the 250lb Welt springs lowered my car, but not as much as advertised.
PostPosted: Mon Aug 13, 2007 1:27 pm    Post subject: Reply with quote
If I'd do it over again, I'd go coil overs for sure, my next suspension mod will be front coilovers.
PostPosted: Tue Aug 14, 2007 5:01 am    Post subject: Reply with quote
If I understand it right, I can also use the standard springs and just lower the coilcover from the strut ? I don't need adjustable ones.
