charging system
Lizard
PostPosted: Fri May 31, 2002 10:29 pm    Post subject: Reply with quote
hey guys last night my battery light just came on, turned the car off came back to start it battery was drained, and then it wouldnt carge what are the first things to check, alternator, regulator, charge at battery all that fun shit
Diesel
PostPosted: Sat Jun 01, 2002 1:37 am    Post subject: Reply with quote
Make sure the belt's still there.
marky522
PostPosted: Sat Jun 01, 2002 5:12 am    Post subject: Reply with quote
Double check your grounds, i had the ground right off the battery melt its self cause i didnt have any other grounds. and it died just like that.
Mark
PostPosted: Sat Jun 01, 2002 6:29 am    Post subject: Reply with quote
Charge the battery, start the car and check the voltage at the battery. You should see something like 14 Volts or more if the alternator is charging.
gohim
PostPosted: Sat Jun 01, 2002 4:31 pm    Post subject: Reply with quote
Check the cables that run from the battery to the starter, and alternator.
Battery acid has a tendency to run down the positive cable, and eat it from the inside-out, leaving the insulation cosmetically intact, while the wire has gone.
If that happens, the battery won't charge, then the starter may act strangely, just before the battery goes flat, because it is not charging, and the ignition system is drawing over 10A.
Lizard
PostPosted: Sat Jun 01, 2002 10:08 pm    Post subject: Reply with quote
thats gohim and everyone i think it is either the switch inside the starter or the wire going from the altenator to the start or the starter to the battery although i have a wire running straight from the altenator to the battery and that holds the system up while i am driving but it isnt that great because it is showing that it is only charging at 12.5 at the battery but when i tested it at the altenator it was showing 14.5, bad ground, anyway thanks for the help
