My 924 is surging bad at low RPM
ushawk1
PostPosted: Sat Jan 13, 2007 5:32 pm    Post subject: My 924 is surging bad at low RPM Reply with quote
If I hold steady while driving in the 1500-2800 range, my car surges bad. Like it has a horrible miss. It idles high but great at 1400-1600, and will accelerate through the RPM range smoothly. I was thinking my fuel accumulator may be bad. It turns over forever before it starts, regardless of temperature. I hate having to drive everywhere at 3500-4000 cruise speed. I know it is nearing time for a valve job. Possibly oil squeezing past and killing some cylinders at those speeds? Compression test is within limits, but at the lower limits. Any ideas?
Shut up fool, those are mine.
Ozzie
PostPosted: Sat Jan 13, 2007 10:07 pm    Post subject: Reply with quote
Pull your injectors and check the spray pattern.
Its AUTO and its BLACK
Montego Black on black/red
