Cooling System Fan Switch
Schreiberdeutsch
PostPosted: Mon Nov 27, 2006 9:05 am    Post subject: Cooling System Fan Switch Reply with quote
What type of fan switch do I need for my 87 924S....
I would like to say, it normally never went past the middle marker (on the temp gauge) but after it went out it would overheat.... only once and then i found out that turning on the AC would force it on so to speak...
so which one should I get....
75-70 Degree
82-77 Degree
65-60 Degree
87 924S (Wrecked)
$5,000 worth of work done to engine
1995 Mustang GT 5.0
PostPosted: Mon Nov 27, 2006 10:58 am    Post subject: Reply with quote
It should match your thermostat in the water pump.
20v924
PostPosted: Mon Jan 29, 2007 10:24 am    Post subject: Reply with quote
I would replace them both if your going that far.
A person is smart. People are stupid
dash16
PostPosted: Thu Sep 27, 2007 3:03 pm    Post subject: Reply with quote
how do you check for that? I have the same problem. i want to get the fan switch replaced but I don't know which temperatures to buy the switch at
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
