Initial findings on my 924S...pics inside
FASTdan
PostPosted: Fri Nov 17, 2006 7:08 am    Post subject: Initial findings on my 924S...pics inside Reply with quote
Hi Guys,
Ok so i finally got round to investigating my new non-running purchase ('86 924S).
First finding....hmmm something missing here:
Fuel pump relay. Can anyone give me details on this component so i can order one? part no? identifying marks? type? as obviously i dont have one to match up to.
Would I be right in thinking this relay also switches power to the ECU? so without it there would be no voltage to the coil?
Secondly, the balance shaft belt is worn as its rubbing against this:
Im guessing it shouldnt be - but the question is what is that component? and why is it interfering with the belt?
Third, another random 'roller' looking object that seems to be doing nothing:
As above, what is it? and should it be doing something its not? doesnt appear to rotate?
Finally, random outlet on the water pump with no pipe attached - should there be?:
All help much appreciated, cheers
Dan
1980 924LUX
alexvex
PostPosted: Fri Nov 17, 2006 10:37 am    Post subject: Reply with quote
As for the waterpump...mine is like that too as I just replaced mine. That's actually probably a good sign as the waterpump has probably been changed. The nozzle is a block off plate for the 951. If you have a 951, then you just drill out the nozzle to go to the cool the turbo. As for N/A 944/924S, then you just leave it like it is.
--Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
FASTdan
PostPosted: Sat Nov 18, 2006 5:45 am    Post subject: Reply with quote
Ah, that makes sense. I think it has had a waterpump change as im sure i saw a receipt for it. will check when/mileage. Thats 1 less thing to worry about then.
You can actually see on the 2nd picture the damage to the balance shaft belt - the teeth have worn across half the belt due to the rubbing on the component i mention.
1980 924LUX
timstar92404
PostPosted: Fri Nov 24, 2006 6:54 pm    Post subject: Reply with quote
wow, that timing belt / balance belt area looks scarey to me. the balance belt teeth definately shouldn't be that worn down, thost belts will definately fail pretty fast if you run it like that.
I would replace all rollers/ belts and tension them properly before running it. It looks like you have the updated pump by looking at the block of plate, so that smaller roller is the wrong roller for your water pump, that is why it is not touching hte belt. The correct roller is larger and will touch the belt You will probably have to also replace all the oil seals behind the belts or else your new belts and rollers are going to be all greasy and oily and that will wreck your new belts.
78 924 sold.
85.5 944
FASTdan
PostPosted: Sat Nov 25, 2006 3:59 am    Post subject: Reply with quote
Thanks for the replys chaps.
I actually think the cam belt looks fine obviously i WILL replace it but its not at all damaged and looks like its hardly been used. Of course the balance belt is fooked but whats the worst that would happen if this failed? Engine goes out of balance?
I would like to get it started as it is then i know its a runner before I start messing with the timing belts etc?
So what seals do you replace when doing this front end service? Crank shaft? Balance shafts?
Whats this about an upgraded water pump? and how do I source the larger roller? Whats the point to it, as its on the tension side of the belt - just to stop any bouncing? Is there a part number? Or is it a 951 part?
thanks for all the help and sorry for all the questions!
1980 924LUX
Hoboceratops
PostPosted: Sat Nov 25, 2006 7:10 am    Post subject: Reply with quote
I'll play gohim here for a sec.
Tow it to a dealership / porsche shop and have the front engine service.
Also, that roller that has ruined your balance shaft belt is the idler roller... but it doesn't look right at all, as if it's either a completely wrong part or it's somehow been worn down a ton.
Yeah... Unless it's going to be a project car and you're a whiz mechanic, I'd say take it to a shop.
1987 924S: Very much in love with it, even if it's all finnicky
Tello65
PostPosted: Sat Nov 25, 2006 8:18 am    Post subject: Reply with quote
the small roller ist from the 944S2, the silencer underneath the automatic
camshaft tensioner. the correct one for your car should be a black plastic one.
better get all of it replaced before you even try to start that thing
FASTdan
PostPosted: Sat Nov 25, 2006 11:32 pm    Post subject: Reply with quote
Sorry but that simply aint happening The car cost me £400, max return i could ever see on it is £2000 with a LOT of work so there's absolutely no chance this thing will be going near a porsche workshop!
I'm a professional mechanical engineer so im well aware of the principles and im also reasonably competent in car maintenance so I think i'll take my chances and DIY it.
1980 924LUX
PostPosted: Sun Nov 26, 2006 12:18 am    Post subject: Reply with quote
Alrighty then...I'd replace everything that touches the belts based on those pictures.
And the oil seals. Might as well reseal the oil cooler...
Have you seen this?
http://www.clarks-garage.com/shop-manual/eng-06.htm
PostPosted: Sun Nov 26, 2006 12:28 am    Post subject: Reply with quote
Here's one source, you will need almost everything that has timing belt or balance shaft in the description plus the water pump and oil seals.
http://www.autohausaz.com/search/group.aspx?sid=vq13qp45ukdh222b0vmk3nis&makeid=800019@Porsche&modelid=1263316@924%20S&year=1987&cid=20@Engine%20Parts,%20Seals%20%26%20Gaskets
gohim
PostPosted: Sun Nov 26, 2006 8:52 pm    Post subject: Reply with quote
If you are looking at your 924S strictly from a financial angle, you might as well dump it right now. You will never get back the money that you are going to pay to get repair the existing damage, and catch up on maintenance. Maintaining a 924S or 944 in good running condition costs an average of $800-$1000 a year when you take into consideration the cost of incidental repairs, scheduled maintenance, and a reserve fund to cost the 3-year or 36K mile front of engine service.
I have no doubt that the car is in need of additional parts and repairs based on the condition of the engine from the photos that you posted.
The parts to perform the front of engine service will cost you $600-$1000 from an aftermarket source, depending on who you buy them from, and whether you go for a new or rebuilt genuine or generic water pump. You also need to spend between $200 and $700 (depending on whether you go with genuine tools or decide to take your chances with the generic substitutes) for special tools that will only be used on a watercooled Porsche. If you end up taking the car to an authorized Porsche Dealer, the cost of front of engine service and the oil cooler seal replacement is going to be in excess of $2000 with parts and labor. Parts are priced considerably lower here in the U.S. and you should investigate purchasing them in the US and having them shipped to you. BUT if you don;t already know it, the cost of shipping to foreign countries from the US can be extremely expensive.
The reason that your car is in the condition that it currently is in is that the PO (Previous Owner) either could not or chose not to perform the necessary services properly to keep the car in decent condition. You, are (unfortunately) going to pay the price of the PO's actions.
FASTdan
PostPosted: Mon Nov 27, 2006 4:57 am    Post subject: Reply with quote
I'd say im looking at this 924S 80% from a financial angle and 20% from an enjoyment point of view. I only bought it because of its price tag really, that and the fact I've had a normal 924 and decided I'd like the next model up.
The last one was purchased for £470, I sunk £400 into it (engine rebuild) and returned £1100. That gave me 3 months enjoyable (although sh*t slow lol) motoring and a decent profit for my efforts.
Maybe this one wont work out like that (yes i know this one has a REAL porsche engine lol), but hey its all good fun. I have a source for parts who is at the top of the supply chain (ie he sells to parts stores so gives me them at their absolute base cost) so that helps.
Thanks very much for those links Paul, they look excellent! And thanks to everyone else for the advice. I'll shortly be posting a new subject regarding the lack of power to the fuel pump
I'll start looking into the parts i need for that front of engine service this week.....
1980 924LUX
FASTdan
PostPosted: Wed Nov 29, 2006 3:16 am    Post subject: Reply with quote
A small update.
Having checked through the serive history I have discovered that infact the water pump, timing belt tensioner and both belts were replaced within the last 10k miles (I thought the cam belt looked in good condition!). So hopefully all I will be replacing is the smaller rollers, seals and belts .
1980 924LUX
gohim
PostPosted: Wed Nov 29, 2006 6:58 am    Post subject: Reply with quote
You need to realize that time, as well as miles is an indicator of when the "front of engine service" should be performed.
If the belts and waterpump were changed 5 years ago, even though they have only accumulated 10K miles since, they would still be due for replacement now, based on time.
I am sure that since you have been checking old post on this Board that you are aware that when the belt, if one belt fails, the other is also tossed off as a result, and that when they get old, they have a tendency to strip teeth (and jump timing as a result).
The result of such an occurance is usually atleast four bent valves (@ $75-$100 a valve for parts) best case, and worst case, a valve head breaks off and wedges in the cylinder, damaging or cracking the cylinder (requiring a replacement engine block to repair).
To replace the front of engine oil seals, you are going to have to remove the belts anyway. So why re-install an old belt with a short service life?
FASTdan
PostPosted: Fri Dec 01, 2006 8:26 am    Post subject: Reply with quote
As I said dude, I intend on replacing both belts
1980 924LUX
