Fuel system problems
dan476
PostPosted: Thu Nov 09, 2006 11:54 am    Post subject: Fuel system problems Reply with quote
After 2-3 years this car sat without running(maybe more, who knows), fuel pump was pronounced dead (everytime power was applied, it made one clunk and wasn't spinning inside), i pulled it off, soaked it in carb cleaner and pumped some water through it, applied power again and it still made clunk noise and wouldn't pump. I drained my fuel tank and pulled fuel strainer off, first thing i could say was holy f@#k
and here is why:
what do you guys suggest i do? i am going to get some more carb cleaner and clean the strainer with it.
What should i do with my fuel tank?
Dan
D Hook
PostPosted: Thu Nov 09, 2006 9:21 pm    Post subject: Reply with quote
Drop the tank and take it to a shop that specializes in fuel tanks, have it cleaned and inspected for rust-through, then have them put a liner in it if it's still good.
Good used ones are getting harder to find but not impossible. Plastic ones are available from 944's but they require modification to body understructure to fit, is what I understand. Don't know if anyone's actually tried it or not.
Good Luck!
'80 924 n/a SOLD
Mike924
PostPosted: Fri Nov 10, 2006 5:48 pm    Post subject: Reply with quote
I raised this point a while ago and Lizard's emphatic reply was: forget it!
D Hook
PostPosted: Fri Nov 10, 2006 8:49 pm    Post subject: Reply with quote
Yes, I believe Gohim had the same opinion.
'80 924 n/a SOLD
dan476
PostPosted: Sat Nov 11, 2006 3:21 am    Post subject: Reply with quote
like how much modifications are we talking about?
Dan
Mike924
PostPosted: Mon Nov 13, 2006 5:45 pm    Post subject: Reply with quote
Enough to scare seasoned tinkerers like Lizard and Gohim off!
PostPosted: Tue Nov 14, 2006 1:49 pm    Post subject: Reply with quote
any good tank shop should be able to repair it unless the whole thing is rotten through and though. Though you said there was fuel still in it before, so it cannot be that bad and will be repairable.
btw I would recommend that you just replace the high pressure pump. Reason is that if you dont now you will be shortly, and I would not consider those pumps to be repairable.
3 928s,
