warm up regu;lator
porscheslave
PostPosted: Wed Sep 27, 2006 4:43 am    Post subject: warm up regu;lator Reply with quote
How can ut tell if the wur is bad. The car seems to be rich all the time. I've changed the fuel dist, turbo, fuel injetors, plugs,and gutted the cat. It still wants to run rich. Can ti be the WUR.
Thanks
Ozzie
PostPosted: Wed Sep 27, 2006 7:27 am    Post subject: Reply with quote
Your model car would help.
I guess about an '81?
Its AUTO and its BLACK
Montego Black on black/red
dpw928
PostPosted: Wed Sep 27, 2006 11:01 am    Post subject: Reply with quote
The WUR can be tested by performing a cold and warm control pressure test.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Mike924
PostPosted: Wed Sep 27, 2006 5:02 pm    Post subject: Reply with quote
Why have you changed all those things? What's wrong with doing the proper adjustment for idle mixture first?
How are you determining that the car is running rich? Did you adjust the new fuel dist after you fitted it?
Tello65
PostPosted: Wed Sep 27, 2006 5:12 pm    Post subject: Reply with quote
The WUR can only be testet with a gauge. I schould be at 2 bar when cold and go up to 3.5 bar when warm
this is a new testgauge, like the original with is N/A
http://www.transaxle-sportwagen.de/shop/product_info.php?info=p13_K-Jetronic-Pr-uuml-fadapter-P378.html
Stampedetrail
PostPosted: Thu Sep 28, 2006 3:53 pm    Post subject: Reply with quote
Listen to this fellow. Buy yourself a 3 mm allen wrench.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
