VW pistons + 931 head
PostPosted: Sat Jul 22, 2006 8:08 pm    Post subject: VW pistons + 931 head Reply with quote
Has anyone used the 10:1 VW pistons in combination with a 931 head and if so..
do you have an interferance motor?? or can you confirm compression ratio...
thanks
Leadfoot
924SSilver
PostPosted: Mon Jul 24, 2006 12:41 pm    Post subject: Reply with quote
which VW pistons?
PostPosted: Mon Jul 24, 2006 1:02 pm    Post subject: Reply with quote
type 1 flat tops.
Kenodog
PostPosted: Mon Jul 24, 2006 3:27 pm    Post subject: Reply with quote
iirc Racing said that with a stock head they were around 11:1 . You need to cc the head to run them on stock rods.My .02
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Tue Jul 25, 2006 6:10 am    Post subject: Reply with quote
whats "cc" please ?
PORSCHEV
PostPosted: Tue Jul 25, 2006 8:18 am    Post subject: Reply with quote
carbon copy...come on "duh"!
I was wondering the same thing
1978-#53 "D" track racer.
PostPosted: Tue Jul 25, 2006 12:34 pm    Post subject: Reply with quote
My calculation was 10.7:1 with the 924 head and 8.9:1 with a 931 head. That's one of the things that leadfoot is checking.
Kenodog
PostPosted: Tue Jul 25, 2006 1:42 pm    Post subject: Reply with quote
cc'ing a head is to remove material from the combustion chamber so that they are all the same volume.This smoothes any sharp corners and adds cubic centimeters so you can do the math and figure out exactly what your CR is.
I'm pretty sure Racing said he cc'd his head to 20 or 22 cubic centimeters per chamber in order to get his CR right for 87mm flat tops.
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Tue Jul 25, 2006 9:13 pm    Post subject: Reply with quote
found the 87mm and 88mm piston kits at an ebay store.. kokoparts $125US...
BTW the bushings for these pins to use with the stock rods are at EBS for $10 each...
